Graphics which company is this 6800 from
Discussion in 'Hardware' started by Abadon, 6 Aug 2004.
  1. Abadon
    Abadon What's a Dremel?
    17 Jul 2004
  2. tmod
    tmod What's a Dremel?
    9 Apr 2004
    Leadtek makes that card, IIRC. I've seen 6800 cards for less (not more than $10, mind you).
    In the listing, the card's speeds are the standard 6800 speeds, whereas BFG, Gainward, XFX, and others may sell their cards clocked at higher speeds to begin with. It depends what you're looking for, because I'd imagine that cooler, on the other hand, is (somewhat) better than the standard 6800 cooler, if you're looking to overclock.
  3. Tim S
    Tim S OG
    8 Nov 2001
    tmod is correct, it's a Leadtek
