Cooling Which Cooler for Gigabyte P35-DS3R?
Discussion in 'Hardware' started by Atomic, 31 Dec 2007.
  1. Atomic
    Atomic Gerwaff
    6 May 2002
    I need a silent cooler that will fit onto the P35-DS3R. I'm not into OCing or Gaming, so dont need to shift a lot of heat.
    I've currently got a Scythe Ninja in my setup, so something as quiet as that would be nice...
    Any thoughts?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Another Scythe Ninja? I'm pretty sure they fit no problem. If you've heard otherwise let me know, I'm considering one for a DS3L but the premium over the £15 AC Freezer Pro 7 puts me off.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    I assume I'll need to buy a new mounting bracket for the ninja to change from 939 to LGA?
    edit: might be one in the box... thinking about it I've not looked since I installed it!
  4. Omertron
    Omertron What's a Dremel?
    14 Feb 2007
    I have the Gigabyte P35-DS3R and with the stock cooler on a E6750, I can't hear the cooler at all, even when playing games. Try the stock cooler and replace if needed would be my advice :)
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    I only have two fans on my system, the PSU is silent (under 20db) so anything louder than that is going to annoy me.
