Displays Which Dell?
Discussion in 'Hardware' started by Yeoo, 11 Nov 2011.
  1. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    So the Gf says what do i want for xmas and i have decided a monitor now i can get Dell at good price so im a bit stuck as to what to do..
    3x U2311
    1x u2410
    1x u2711
    i do a bit of gaming and web design and want to start doing a bit of photo editing video editing. So it has to be a good all rounder. Help me :(
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    With your GPU, none of them for gaming :p
    But seriously, you'll need a beafier GPU for those res's :)
  3. GoodBytes
    20 Jan 2007
    U2311H is discontinued, replaced with the U2412 (same thing but with white LED's as back light and cheaper stand)
    2x U2312 will be very demanding for your GPU Same for the U2711. Resolution is very high for both setup.
    1x bigger screen is better for gaming, as all games will properly support it. While the triple monitor setup, give you more work space horizontally. It depends on you.
    U2410 is in between both... you have the cool features of the U2711, mixed with the small size monitor, in the sense that the monitor is lower resolution, which will be much less of a problem for your GPU at playing games, and it's 16:10, which provides you good work space (Well it doesn't really mater for now on the U2711 as the resolution is much higher), but does, in my opinion, over 16:9 1920x1080 (assuming comparing 1x monitor setup for both).
    I can't say for 2x or 3x 1080p display setup with heavy multitasking, I never tried it.
  4. longweight
    7 May 2011
  5. Parge
    16 Jul 2010
    Well he has 'next build i5 2500k' in his sig so I'll assume he won't be using the 6750 for gaming.
    If not I'd go for the biggest one you can afford. I have a panel similar to the 2410, and frankly its brilliant. I'd like a U2711, but I can't afford it, or the GPU required to drive it in games.
  6. longweight
    7 May 2011
    Your 570 would be fine for gaming! Mine runs my U2711 really well.
  7. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    If you can squeeze a little more 2 x U24 would be a good move.
    As you can use one for gaming at decent fps.
    Then when you are in work mode use the two, makes a big difference it's as good as having two PC's.
  8. longweight
    7 May 2011
    But the U2711 is basically big enough to have 2 screens worth of stuff on it :)
  9. Parge
    16 Jul 2010
    Ah but I'm a graphics whore and I almost exclusively play BF3. I can run it in Ultra with FXAA at 1200p but I doubt I could go much higher and still maintain 50+ fps in MP.
  10. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    GPU can be upgraded, Im constantly changing things and if i need to change GPU i will do. Girlfriend wants to buy my a screen for Xmas so ill let her lol.
    Im still no closer to deciding lol
  11. longweight
    7 May 2011
    I looked into the 2410 and the 2711. So glad I went with the 2711!
  12. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    What do you use yours for?
  13. Pookeyhead
    30 Jan 2004
    Pah!... none of them. Get the 3011. :)
  14. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    +1
    Funny how this one is often overlooked - probably its price. I considered (and came very close to getting) the U2711, but I simply cannot stand the pixel pitch even though it's a very nice monitor.
    U3011 incoming when I sell some of my gear...
  15. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  16. Tangster
    23 May 2009
  17. longweight
    7 May 2011
    I can feel a U3011 coming on when I get my bonus next year.... And I will be selling the U2711. I just want the extra height.
  18. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    I found it for £420 when the Dell U2410 on Scan is £430.
    I can get a brand new Dell U2410 for £330 though so i doubt ill get something better value..
  19. GoodBytes
    20 Jan 2007
    Glossy, non adjustable stand, and lots of reports of 0 after sale services, minimum monitor OSD options.. I think it's no.
  20. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    I'm not saying its as good a a U2711 but it does cost £400 rather than £600.
    That's kind of what that review says basically.
