Electronics Which diode?
Discussion in 'Modding' started by 2800@2.5ghz, 11 Nov 2005.
  1. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    i'm currently in the middle of modding a mini-itx into a NEs and to wire up the controllers to the parallel port i need some diodes.
    i've been on maplin and there are different types such as switching diodes and rectifier diodes?
    which one would be the best to use in this case. does it really matter?
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    Here's a good page on types of diode :)
  3. Mattt
    Mattt Minimodder
    12 Nov 2001
    can we see the circuit diagram you are working from please.
    this should prob be in the electronics section btw. :)
  4. 2800@2.5ghz
    23 Mar 2005
    Thanks for the replies guys, but it seems as if there is also the required diodes on a small PCB on the NES's controller socket so theres no need for me to buy any
    Thanks anyway chaps :)
  5. Nexxo
    23 Oct 2001
    Moving to Electronics....
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's not critical at the current and voltage involved; 1N4148 is one to go for -- small size, fast, cheap, and sold everywhere.
