Linux Which distro for a dedicated http server/ router?
Discussion in 'Software' started by Naked_Dave, 22 Jan 2004.
  1. Naked_Dave
    Naked_Dave What's a Dremel?
    30 Nov 2003
    I'm currently running win XP on my server, after having given up on using SuSE (for some reason i couldn't get it to work as a router, no matter what i did), and although i've had absolutely no problems with it, i want to go back to something unix based anyway. So which distro/os would you suggest? I was planning on using slackware, but then i saw that tsl was actually designed purely for servers, although it looked rather complicated and unfriendly!
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    i used redhat 9 the first time then switche to mandrake 9.2 becouse redhat would fun mt fan on high ALL the time. mandage to get a working server going both times using litespeed http://litespeedtech.com/ website in sig.
  3. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
    Was using Redhat 9 but seeing as they are stopping support for it I changed to fedora 1 at the start of december 2003 and i've have no problems yet.
  4. herbs
    herbs Nobody but us chickens
    7 May 2001
    Download e-smith SME server as its free and is set up as file/printer and router out of the box. get it here
  5. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Try IPCOP- its free, easy to setup and I've never had any problems with it.
    Sam
  6. herbs
    7 May 2001
    He wanted a http server too.
  7. cderalow
    cderalow bondage master!
    23 Jan 2002
    debian/free bsd.. or if you're feeling lucky... gentoo
    all free if you have a good internet connection (legitimately too!!!)
  8. Uncle Psychosis
    27 Jul 2003
  9. RTT
    RTT #parp
    12 Mar 2001
    FreeBSD-4.8, Slackware. Gentoo is on my list of things to try. I didn't get on well with debian at all, ugh...
    fBSD/Slack = :D
  10. Naked_Dave
    30 Nov 2003
    I'm now using TSL, it installed far more easily than i expected (couldn't get slack to install at all!) and seems to be working pretty well.
