Linux Which distro for P3 machine?
Discussion in 'Software' started by hitman012, 16 Oct 2005.
  1. hitman012
    hitman012 Minimodder
    6 May 2005
    Hi,
    I've decided to delve into the world of Linux and plan to install it on one of my old machines and look. However, it only has a P3 600MHz and 256MB of RAM, and I'm wondering which of the many versions out there would run well....or am I overestimating the system requirements?
    Thanks.
  2. Go4t
    Go4t i
    13 Dec 2003
    linux isnt like windows, it doesnt need a lot to run good
    any distro (new/old) should work fine
  3. serial_
    serial_ What's a Dremel?
    11 Oct 2005
    I'm running a p3 500 oc'd to 560 with slackware 9.0, I like it just fine, the latest distro of slackware is available for download on their ftp.
    Slackware is my personal preference. But to each his own :) I like it because it provides you with just enough ease, but without feeling like it's trying to be windows.
    - serial_
  4. hitman012
    6 May 2005
    Thanks for the replies. When I find that old 10GB hard drive, I'll give them a try.
  5. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'm using Debian on my dual P3 866MHz. Made a custom kernel and it's all good :)
  6. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    If it's linux, it should work. I'm running slackware on an old IBM Aptiva with a 233 and 16MB ram. :naughty:
  7. serial_
    11 Oct 2005
    It's crap like that that makes linux (*cough*slackware*cough*) sexy.
    - serial_
  8. kiljoi
    13 Oct 2003
    I couldn't agree more. Also, if you're looking to make a linux router, I recommend Smoothwall. It's running on a 200 with 32MB ram (old compaq).
