Modding Which dremel cutting bit for cutting alu?
Discussion in 'Modding' started by tken, 7 Dec 2006.
  1. tken
    tken What's a Dremel?
    1 May 2004
    hi guys
    between dremel 561 (Multipurpose Cutter) and 9903 (3.2 mm Tungsten Carbide Cutter), which one is the best for cutting alu/plexi/acrylic?
    cheers
  2. Firehed
    15 Feb 2004
    While I've hardly memorized the different dremel bits, I always use the fibreglass-reinforced cut-off wheels for alu. Occasionally the standard heavy-duty ones (those dark sand-ish ones), but only if I don't have any of the better ones available.
    Likewise for acrylic, just set it to go really slow so it won't melt all over the place.
  3. tken
    1 May 2004
    I got those fibreglass-reinforced cutting wheel as well but it seems like its easier with the cutting bits (for straight line, small place etc....)
    thanks for the reply though :)
  4. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    in my experience the fiberglass reinf wheels work well with thin alu sheeting and for straight lines. The cutters are better for curved cuts. I would prefer the Tungsten one.
