Displays Which gaming monitor do people reccomend?
Discussion in 'Hardware' started by Headspark, 4 Sep 2008.
  1. Headspark
    Headspark Minimodder
    23 Feb 2005
    Need a flat screen, its been along time coming, have some cash for one now, just need some advice as to waht to get.
    Around the 21" size.
    cheers
    Andy
  2. Headspark
    23 Feb 2005
  3. spoon.uk
    spoon.uk Frag Me Bitch!
    1 Sep 2008
    Very :) If its too high you will get ghosting and nasty looking pixels just because screen won't cope with fast games like Q3/UT. Sometimes if screen if really shitty you can see than on movies even ;)
    I would go for a bit smaller and better specs:
    http://www.overclockers.co.uk/showp...6BW 22" Widescreen LCD Monitor - Glossy Black
    Good 24" is more than £400 I'm afraid.
    /EDIT
    Of course too high ;)
    Still matters which response time is quoted G to G usually is the best to know and have it as low as its possible.
  4. specofdust
    specofdust Banned
    26 Feb 2005
    What spoon.uk means is if response time is too high you'll see ghosting. However you tend to also want to avoid the other extreme, because last time I checked, the panels that are reporting response times of say, 2ms as opposed to 8ms tended to be a good bit lower quality, simply to satisfy the hyper-fast response time rates. Anything below 16ms should be fine.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
  6. Headspark
    23 Feb 2005
    Thanks for all the help, i think i will get one of those ordered ASAP!!
  7. kesa20
    kesa20 spaceman
    24 Jul 2008
  8. 5hadow
    5hadow What's a Dremel?
    24 Aug 2008
    ^^^ Where did you get these prices? Can you provide a link please ...
  9. Jordan Wise
    Jordan Wise Baby called to see the boss...
    24 Jul 2007
  10. joanne1967
    joanne1967 What's a Dremel?
    25 Jul 2008
