Build Advice which gaming set up???
Discussion in 'Hardware' started by grritsshawn, 30 Dec 2009.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Ok there is these parts i can get idk which ones
    cpu-core i5 750 quad core 2.66ghz or core i5 661 dual core 3.33ghz
    gpu-260 gtx(216 core) in sli or 285 gtx
    motherboard-asus sabertooth/EVGA P55 Cheesecake SLI
    psu-Rosewill BRONZE series RBR1000-M 1000W(3 6 pins,3 6+2 pins)/OCZ ModXStream Pro OCZ700MXSP 700W
  2. The Razman
    The Razman What's a Dremel?
    8 Dec 2009
    Well that really depends on what kind of money you're looking to spend.
    The i5-750 is a quad core which can be easily overclocked to 3.33ghz and beyond, so is obviously the better choice there. Two GTX 260s are easily going to beat a GTX 285 in terms of power.
    That PSU is overkill in terms of wattage, I'd say. You're never going to need 1000W even when you're running SLI. I'd say about 750/850w should do the trick there, but I've never run an SLI/Crossfire rig so other people can advise better on it.
    As for the motherboard ... either should be fine, just make sure it supports SLI and maybe look up reviews on them to make sure they're viable.
  3. grritsshawn
    20 Apr 2009
    well the price for any of those are the same...
  4. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    EVGA make cheesecake motherboards? REVIEW!
    EDIT: My 1,111th post is awesome.
  5. grritsshawn
    20 Apr 2009
    and a evga cheesecake mobo would b pawn
  6. dec
    dec [blank space]
    10 Jan 2009
    cheesecake @ 4ghz!!!!!
  7. grritsshawn
    20 Apr 2009
    how about cheesecake cpu... 10 core stock at 6ghz....max load temp would be cheesecake....
  8. MaverickWill
    26 Apr 2009
    You could bake a cheesecake on that thing. ;)
  9. grritsshawn
    20 Apr 2009
    i'm gunna put off the gpu right now im saving money for everything but the gpu i will use a dell 7900gtx :eyebrow:
  10. dec
    dec [blank space]
    10 Jan 2009
    sig'd
    save as much as you can. fermi 280's may cost more than i7 965 EE :jawdrop:
  11. MaverickWill
    26 Apr 2009
    I've never been prouder! My first signature appearance!
    And yeah, save a lot of money for the GPU. If you don't spend it all, you've got something left over at the end, which could go towards an SSD, or water-cooling. If you don't save enough, you'll be gutted.
  12. grritsshawn
    20 Apr 2009
    there showing the 360gtx and 380gtx at the CES 2010!!
