I am wanting to affix a strip of PVC angle to my desk as the edge is getting knocked by my chair as I am just short a few inches when it comes to rotating the chair. This is the strip http://www.raygrahams.com/products/129853-homelux-pvc-angle-trim-black-243m-x-13mm.aspx not sure whether this is a suitable glue or something else would be better?
It's lightweight and you've got a huge contact area - I would have thought that so long as you've got something that claims to be compatible with both the PVC and desk material, you'll be just fine. A strip of sticky foam would not only stick the angle, but also provide a bit of cushion for when you knock the chair to the desk.
That is a great idea. I have not bought any glue yet so will have a look for some suitable double sided sticky sponge/tape. Thanks.
