Build Advice which graphic card for low end gaming system
Discussion in 'Hardware' started by nukeman8, 21 Jan 2009.
  1. nukeman8
    nukeman8 What's a Dremel?
    24 Jul 2008
    Back for some more help on graphic card choice this time its for a low end gaming system.
    Im going to be buying building 2 low end gaming systems. I pretty much going to follow the bit-tech's low end system in the what to buy hardware guide.
    However i dont fancy spending £150ish on a 4850, surely theres a lower end card that can play modern games at playable (30fps) rates.
    any ideas?
  2. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    There are very good deals to be had on second-hand 8800GTXs that people are selling around 90-100 ish if you dont mind buying secondhand. They are still very good cards, and more then capable of what you want.
    Below that is the HD4670 or the 9600 GT (or whatever it is called now :rolleyes:), both can be had new for quite cheap.
  3. nukeman8
    24 Jul 2008
    im probably going to buy all 2nd hand parts for both of the pcs so 2nd is ok
    i look into 4670's and 9600 gt's
    thanks
  4. Xtrafresh
    27 Dec 2007
  5. nukeman8
    24 Jul 2008
    looks like im to late, someones already claimed em
    nice find thou thanks
  6. kenco_uk
    28 Nov 2003
    Or a 9800GTX+ for around £120..
    Or try your luck (not mine, I hasten to add).
  7. Xtrafresh
    27 Dec 2007
    nah, he's done a bid, but i'm guessing that was too low. Anyway, i'll get my nose out of your business now, good luck on your search :thumb:
  8. badders
    badders Neuken in de Keuken
    4 Dec 2007
    What resolution is this for?
  9. nukeman8
    24 Jul 2008
    1680x1050
    depends on what monitors i get but its likely to be 19-20"
  10. Xtrafresh
    27 Dec 2007
    19" widescreen is mostly 1440x900. Using that will also allow you to cope with a lowerend GFX card for a while. You may find it too low (literally) for office tasks, as 900 really isn't that much.
  11. nukeman8
    24 Jul 2008
    how do you mean too low for office tasks?
  12. kenco_uk
    28 Nov 2003
    As in, not very wide spreadsheets. Opening windows side by side wouldn't be as practicable as it is on larger widescreens.
  13. Xtrafresh
    27 Dec 2007
    no, i mean literally too low. All the generic screens people normally use at an office have 1024 height, 900 is really a lot lower. Compare it to a laptop screen if you will (most of them are 800 high).
    For games, this is usually not a problem. :)
  14. voodoo2k4
    voodoo2k4 Ghetto Modder
    21 Apr 2004
    How would a HD4650 stack up for budget gaming?
  15. badders
    4 Dec 2007
    Works for me, though Left4Dead and Grid have to be lowered to 1360x768 to get 60fps.
  16. Chocobollz
    Chocobollz What's a Dremel?
    25 Dec 2008
    Whoa, really? That's pretty good for a mainstream gc.
    I'd say go for an HD 4650. I think it's a good card for its price, and it will help AMD/ATI if you buy their product :)
  17. badders
    4 Dec 2007
    Yeah, I was surprised actually. It gets 120FPS in HL2, though I can't remember whether that's at 1080p.
    I mostly got it for Blu-Ray Decoding, but thought I'd like to play a few games, especially grid, on the big TV. I think the HTPC needs more RAM though - it struggles a bit with only a GB.
    My sapphire one also came with a DVI-HDMI dongle, so paired with a five-quid HDMI cable from Wilkinsons, it runs brilliantly on my HDTV.
