Graphics Which Graphics Card for Multi-Monitor
Discussion in 'Hardware' started by RinSewand, 23 Sep 2013.
  1. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Hi all,
    Looking for a little help here. I currently run;
    Graphics Cards;
    XFX 5770
    XFX 5450
    XFX 5450
    Monitors;
    Dell 27" (2560x1600) (DisplayPort, DVI)
    Dell 24" (1920x1280) (DVI, D-Sub)
    Dell 17" (1280x1024) (DVI, D-Sub)
    It's just not powerful enough and the current graphic cards struggle. I video edit, photo edit, and watch HD films, but I'm not interested in using it to play games. Currently I can't run Aero without stuttering.
    What do you reckon I should go for? I'd rather spend as little as possible, but at the same time I don't want to skimp if it'll lead to issues in the future. So far my best guess has lead me to two of;
    http://www.scan.co.uk/products/2gb-msi-radeon-hd-7850-oc-4800mhz-gddr5-28nm-gpu-900mhz-1024-cores-hdmi-dport-dvi-plusfree-games
    But I'd welcome some more informed input. Rig spec is in sig. I'd also like to avoid upgrading the PSU, if possible (currently a 580w Corsair)...
    Thanks.
  2. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    A HD 7850 would be fine for a few monitors as long as you're not gaming. You have lots of ram so there shouldn't be any issues.
  3. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Two of the 7850 would be plenty. Heck, one should be enough if you can get the monitors connected.
  4. RinSewand
    11 Sep 2006
    Hadn't considered one - may have to look into adapters to convert the HDMI as well. Thanks for that :)
  5. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Nvidia cards, 600 series and better, can output to 4 monitors also. I'd probably still stick with AMD and wait to see what they unveil on Wednesday, but it's always worth a look at what else is out there.
  6. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Beware of pitfalls. Some cards can only drive a certain amount of displays via certain port types.
    Read up carefully before you pull the trigger on one you like.
  7. law99
    law99 Custom User Title
    24 Sep 2009
    basically the more display ports the better... isn't that the rule of thumb?
