Build Advice Which GTX 580 now!?
Discussion in 'Hardware' started by dave99, 13 Apr 2011.
  1. dave99
    dave99 What's a Dremel?
    26 Jan 2011
    So I was planning to buy an MSI GTX 580 Lightning. It's so nice. Gives me the horn. But it doesn't seem to fit the Silverstone Fortress FT02 (by 1 millimetre apparently):duh:.
    So I am looking for a new GTX 580. I am not bothered about factory overclocks, one way or the other, but I do need it to be quiet and durable as I will not be able to upgrade it for three years.
    I thank you all once again for your patience with my ongoing questions. I know they are annoying.
    When I have built my new machine and used it to take over the world you will be rewarded. Oh yes. :D
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
  3. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    what about the EVGA gtx 580 its what i have got its very quiet and if you register it you can get the 10 year warranty
  4. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    dave99 can you update us to how much of your build you have bought yet?
    Get the MSI 580. It fits the FT02 and as you know, the FT02 is probably the best air case you can get even if the card dumps inside the case, it will be easily dealt with with those 3 vertically pointed 180s
  5. dave99
    26 Jan 2011
    Haven't bought yet, Scan waiting for the FT02 case to come in, I want the non-windowed version. They won't have stocl until 15th May!:wallbash:
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I mistakenly bought two plait 580's (non ref design pcb) which I had to return to Scan as I was water cooling the GPUs, I swapped them for EVGA ref design ones
    But in a air cooled case they would be just fine, slight over clock as standard and quite quiet
    One of the cheaper 580's about too
  7. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    One of the bad thing about Palit is that if you have to rma to them, you will have to send the card to Germany, as they got no UK base. I suppose they are cheaper than brands like MSI/Gigabyte/Asus because of this reason.
  8. Guest-44432
    Guest-44432 Guest
    If your going to keep it for 3 yrs, then go with the one which has 3yrs+ warranty. The 1st year warranty always goes back to base.
    Cheers,
    Simon
  9. Deders
    Deders Modder
    14 Nov 2010
    Also don't forget to secure you case in the event that you decide to act out on your instincts and ruin a perfectly good £350 card for a few mins of pleasure
  10. Blarte
    15 Jul 2008
    Took mine back after two days when it dawned on me they wasnt ref design lol..
  11. Ph4ZeD
    22 Jul 2009
    Things like 10 year warranties never interest me because my graphics cards don't last 10 months before I've sold them :D
  12. Marine-RX179
    24 May 2010
    And let's not forget their custom cooler for GTX460...they cut corner so much that it was loud and poor cooling and with no ram-sink :D
