Build Advice Which GTX 580?
Discussion in 'Hardware' started by dave99, 6 Apr 2011.
  1. dave99
    dave99 What's a Dremel?
    26 Jan 2011
    So I am pretty much ready to buy all the parts I need for my new PC but can now afford a GTX 580 instead of the GTX 570. Whatever I get will be housed in a Fractal Design Define R3 case with extra cooling fans.
    Which one to get though?
    My thoughts are either the EVGA GTX 580 :-
    http://www.scan.co.uk/products/1536...72mhz-shader-1544mhz-512-cores-mhdmi-dl-dvi-i
    Or the MSI Twin FROZR II/OC :-
    http://www.scan.co.uk/products/1536...mhz-gddr5-gpu-800mhz-shader-1544mhz-512-cores
    The FROZR appears to be much quieter and cooler but the EVGA seems to have a better warranty. I am not bothered about the overclock on the FROZR as either card will be more than powerful enough. My main concern is reliability and the noise. I am not a serial upgrader so whatever I get I want to last me a few years and not be too loud as it will be in my main living area.
    I am open to any other card suggestions. These two cards just seemed to look ok.
    Thanks all. :thumb:
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I purchased the MSI and don't regret it. The fact is that no 580 will be silent like lower end cards can be because they guzzle the watts. My 6870 was near inaudible at full load but my 580 definitely isn't, but I accept that because it has 3 billion transistors and smashes most games.
  3. dave99
    26 Jan 2011
    From the reviews I have read the FROZR seems to be quite a bit quieter than the reference design?
  4. Ph4ZeD
    22 Jul 2009
    I don't have the reference design so can't comment really. Having a good case for airflow is essential - I dropped my load temps by 20/30C by changing case, and thus the card doesn't make much noise.
  5. dave99
    26 Jan 2011
    Can I ask which case you had before?
  6. Ph4ZeD
    22 Jul 2009
    I had a Cosmos S. The issue was the only intake was a 200mm side fan, which I had to take out to fit the Fenrir. The MSI dumps the hot air into the case, which will and does result in lower temps and noise providing you have the airflow. So in that case, with poor intake, I got high temps and noise. I changed to a Raven which dramatically changed the situation.
  7. dave99
    26 Jan 2011
    I do like the Cosmos case. especially the pure black one. Was that the same fan layout as the cosmos S?
  8. Ph4ZeD
    22 Jul 2009
    Yes. One of the established weaknesses of the Cosmos cases is the lack of intake airflow.
  9. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
  10. dave99
    26 Jan 2011
  11. lysaer
    15 May 2010
    Good, I don't think i have ever heard anyone use beastly to describe something bad, sorry about my Londoner slang though :)
    I can hit 972 on the core with the air coolers and a slight voltage adjustment and peak temps at 87c
  12. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    im considering the 570 version of that card, heard very good things about the cooler. Tri slot though so make sure you have room.
    you say you have 4 lysaer? how do you fit 4 of them into a case o.0
  13. GeorgeStorm
    16 Dec 2008
    The Direct CUII is the best card currently available, the binning on them actually seems pretty good.
  14. dave99
    26 Jan 2011
    Don't think the Define R3 has the right airflow for a card that exhausts heat into the case.
    I have been looking at alternatives. I like the Fortress FT02 and the Raven but due to their rotated motherboard both cases are too deep for where it is going to live. Any other suggestions? I can spend up to £200 on a case but I like minimalist, and would need it to be reasonably quiet.
  15. Paul2011
    Paul2011 Minimodder
    20 Jul 2010
    the gtx 580 will fit in the raven, im hoping to purchase both the case and the asus gtx580 direct CUII very soon
  16. lysaer
    15 May 2010
    I've got the 570 version in my media centre and it is also a great card.
    I can fit 3 of them on the ud9 the fourth is currently in Dallas Texas with a gentlemen named Bei fei from xtremesystems who is custom making me the water blocks for them
  17. Ph4ZeD
    22 Jul 2009
    My 580 fits in my Raven :p
  18. dave99
    26 Jan 2011
    Sorry, I wasn't clear. The 580 will fit the raven but the Raven won't fit my house. It's a very long case.
  19. dave99
    26 Jan 2011
    Is the EVGA warranty worth choosing it over another brand? It says it has a 10 year warranty.
  20. lysaer
    15 May 2010
    Odds are you will upgrade within a 3 year period anyways, so I would say no
