Storage Which HDD to get?
Discussion in 'Hardware' started by SlowMotionSuicide, 14 Mar 2013.
  1. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    So, I haven't bought a HDD for a long(ish) time and it seems I'm somewhat out of the loop which drive is the current king of the hill.
    What's your choice of mass storage device if you need to buy it today?
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  3. shah
    shah Minimodder
    29 Jan 2010
    They are very good. I have two. But they are a bit slow.
    SlowMotionSuicide likes this.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    if it's only for storage, I find the cheapest thing for the most size with the best warranty. I don't care about performance so much anymore. I don't care if it is Seagate, Toshiba, Hitachi, WD. Whatever is fine.
  5. jinq-sea
    15 Oct 2012
    QFT. Or Blacks or Greens, dependent on budget. WD all the way!
  6. vrrox
    vrrox What's a Dremel?
    27 Apr 2009
    I've got a couple of 1TB WD greens and they've been great. Would buy another if more storage is needed :D
    Sent from Bittech Android app
  7. SlowMotionSuicide
    16 May 2009
    Allright, thanks everyone for your input, I'll take a closer look on WD's offerings.
    +rep for everyone.
