Other Which heat monitoring software
Discussion in 'Software' started by Trenthan, 25 Jan 2009.
  1. Trenthan
    Trenthan What's a Dremel?
    3 Dec 2008
    Ey guys, not 100% if this belongs in here if not sorry
    Im curious to know what cpu, gpu etc software people have found most accurate not 100% but closest, i cant seem to pick one.
    Look at my desktop nothing matches its a 10C from lowest to highest
    Ive tried running prime 95 and with 1 ill get 75C and with another ill get 65C just after so the components are already hot and should produce more heat, let it test for the same amount of time and its cooler????? (btw i only ran 1 each time with prime 95 not all, than i tried all and the results were similar to them being ran on their own.)
    Any idea's lol???
    Cheers Trent
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The temparature shown depends on the TjMax setting. It should be 100°C for Core 2's, dunno about Core i7.
  3. opal
    opal Eh?
    21 Jan 2009
    I think RealTemp is the most accurate
  4. capnPedro
    11 Apr 2007
    I use speedfan. Use Orthos or something to hit 100% load until your temps max out, then do a hard reboot, check your temps in the BIOS andd add a few degrees.
    Diff the BIOS and software readings then you have a fudge factor to add/remove from the software temperature to get the real temperature.
    I find it's all comparative work anyway when tweaking my cooling.
  5. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    I usually use hardware monitor, purely because I've found speedfan to be really way off, but hardware monitor is usually consistently slightly on the high side, which is where i'd prefer to be, so I'm more cautious with overclocks.
  6. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
