Which heatsink...
Discussion in 'Hardware' started by Loz, 18 May 2002.
  1. Loz
    Loz Blah Blah
    16 Apr 2002
    I'm considering buying a decent heatsink and I was wondering which of these two to get:
    1)Cooler Master Heat Pipe HHC-001
    2)Alpha PAL8045
    I've heard that the coolermaster is quite good with the heat-pipes, but absolutly everyone reccomends the alpha :)
    Which would provide the best performance and what are the possibilities for sticking a 120mm delta on either? :D
    ~Sepherus
  2. Loz
    Loz Blah Blah
    16 Apr 2002
    While I'm posting, whats the TS Heatronics Zen CPU Radiator like? Theres no real chance of me getting this (look at the price) but I'm curious :)
    Any probs fitting any of these three to my mobo? (KR7A-133R)
  3. wip3out
    wip3out What's a Dremel?
    8 Jan 2002
    I too am looking at geting a PAL8045 and fitting it sometime in the future when i have thhe time to dismantle my whole computer. :sigh:
    A few questions :-
    Should I get a CPU shim for use with it (OCS says i should but i think this might be to make more money :lol:??
    How exactly do the fans attatch to the heatsink and are 80mm the standard size??
    Will I have any problems fitting it with an Asus A7V266-E revision 1.07 board???
    Thanks
  4. George
    George Bah
    14 May 2002
    get the Alpha, and yes 80mm is the standard size for these HS's.
    .icecube
  5. George
    George Bah
    14 May 2002
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    a shim is used to protect the core of the chip from being crushed. As the alpha pal 8045 bolts on to the motherboard there is no need for a shim.
    You can get 80 > 120mm adpaters if you live in the US as i have seen them on a website a while ago.
    I would recommend the alpha pal 8045 :D
  7. wip3out
    8 Jan 2002
    I think my version of the A7V266-E doesn't have this problem I'll find a pic later to show you what i mean. Anyone one have a 8045 and an A7V266-E??
    ^ my mobo has a diffrent layout of the capacitors
    ^My mobo capacitor layout
  8. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Look through the archives of this forum for a thread called "Dangerous Heatsinks".
    Then buy the Alpha.
  9. Lazy
    Lazy Meow?
    13 Nov 2001
    why don't you make a sticky just saying - buy the alpha pal 8045 as i seem to be telling people a lot lately. :D
    Also make the dangerous heatsink list a sticky as that would probably help a lot of people.
  10. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Ok. I'll do that....at the time I did ask if people wanted it that way, but didn't get a lot of response.
  11. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    wipeout...it does fit on the asus...look at my sig...
    ASUS plus ALPHA....:D
  12. wip3out
    8 Jan 2002
    what capacitor layout have you got near the zif socket flix? the top picture or the bottom one??
  13. GunDam
    GunDam Minimodder
    9 Feb 2002
    With all the recommendations of the Alpha sink we all make here, we should get an Alpha/Bit-tech special price like the Matrix Orbital/Bit-Tech LCD :D
