Modding Which High Brightness LED?
Discussion in 'Modding' started by Dragon, 28 Mar 2003.
  1. Dragon
    Dragon What's a Dremel?
    20 Jul 2001
    I havent a clue about electronics really :blush: (all I can do is the soldering iron bit :D ) so I need someone to just give me the right maplins codes.
    I tried using that resistor guide, but Maplins talks about forward reverse voltages and all sorts of rubbish :worried:
    Had my first attempt at modding my boomie 2k, but I want higher power LED's and Im going to change them around a bit.
    So If someone could just post up the codes, obviously its a 5v power supply as its on USB. 5mm and 3mm green LEDs please and whatever resistors they need.
    And if you are wondering
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Let's say you have a LED at 20mA and 3 volts.
    Excess voltage: 5V - 3V = 2V
    What resistor to use:
    R = U / I
    R = 2V / 0,02A
    R = 100 Ohms
    So what you need is a 100 ohm resistor. The color code for these is brown black brown.
