which is the best browser for win xp
Discussion in 'Tech Support' started by achtani_jeetu, 23 Jun 2008.
  1. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Firefox 3
    IMO, if IE were a snack it'd be a poo sandwich. Unfortunately we still have to use it at work for bits and pieces and the differences between IE and FF are very noticeable.
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    If you will use extensions (which you will) ff3
    If you won't then maybe consider Opera
    ff3 is better though :D*
    *yes I know that all depends on your definition of better.
  3. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    my definition of better is better then your definition of better
  4. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Opera, definitely.
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Opera +1
  6. wongy2803
    wongy2803 What's a Dremel?
    24 Jun 2008
    Personaly FF3 due to the amount of customization you can do with extensions etc.
  7. airchie
    airchie What's a Dremel?
    22 Mar 2005
    For security, FF3 + NoScript extension for teh cheesecake! ;)
    Memory usage however, FF3 sucks.
    However, its not like most machines are short of memory and its there to be used. ;)
    However, I found if its kept open with multiple tabs for a long time, it gets SLOOOOOW. :/
    Not used Opera lately though so can't comment. :)
  8. Cupboard
    30 Jan 2007
    I have found it to use a lot less (like 1/3) memory than FF2 did
    And there have been some studies that show it to use less than all the other browsers
    http://lifehacker.com/396048/speed-testing-the-latest-web-browsers
  9. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    'nother vote for Opera.
    Not I'm sure that FF is bad just that I'm more used to Opera & have no reason to change (I'm sure that this goes for many of the FF users in reverse) - never underestimate userfamiliarity & inertia.
  10. GavX
    GavX What's a Dremel?
    5 Apr 2008
    I honestly can't see whats wrong with IE7. I am not saying Firefox is bad, I used it before IE7, but it has all the tricks that I need in a web browser, and USUALLY nothing gets into my machines that is bad as I have firewalls etc set up. Opera is ment to be the fastest at loading pages, some comparision on n4g.com between Opera, FF3 and IE7
  11. wolfticket
    19 Apr 2008
    IE7 is a fine browser.
    However, my vote goes for Firefox 3 and:
    - Adblock Plus
    - British English Dictionary
    - Copy Link Text
    - CustomizeGoogle
    - DictionarySearch
    - Extended Copy Menu
    - Extension List Dumper
    - FlashGot
    - IE View Lite
    - Java Console
    - Menu Editor
    - Right-Click-Link
    - Split Browser
    - StumbleUpon
    - Tab Mix Plus
    - User Agent Switcher
    Does anyone still use K-Meleon? I used it for a bit, and my tab shortcuts (in TMP) are still modelled on it.
  12. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Been using Opera since 7.something and still loving it. If you want customizability, go with FF, if you want it to work and not be MS, go with Opera.
  13. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Opera all the way, latest one, with the classic 9 skin, hate the new skin with a passion...
    Guess i'm just resisiting change :p
