Notebooks which laptop for Photo editing
Discussion in 'Hardware' started by whisperwolf, 14 Jan 2012.
  1. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    Ok after my current laptop has just gone ping, its moved up my time line for a new machine, I'm looking for a full HD laptop with a matt screen to replace it, with its secondary purpose to be used for running elements 9 or 10. I'm currently looking at a Dell 17 XPS, 8G ram, 750 HD, GT555M 3gb i7 2670QM
    or a medion ERAZER® X6819 with a I7 2670QM, 15", GTX570M, 500gb hard drive, 80gb SSD drive and 4g ram with the aim of upping the ram to 8gb.
    Thoughts on which would be better? or alternatives?
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    How much are you able to spend?
  3. Pookeyhead
    30 Jan 2004
    Dell.. bigger screen. Personally I get irritated if using photoshop on anything less than a 24" screen, so bigger the better. Both have same RAM (or will do).. same CPU... so go with the biggest screen. Dell has bigger HDD too.
  4. whisperwolf
    1 Sep 2004
    Limits about 1k sterling.
    I've currently been using elements on a 12" screen so currently anything will be better, but the larger screened dell is I think the forerunner. I have a 21" screen I can plug into if needed for really detailed work. I just wasn't sure if the better graphics card will be used by elements or not.
  5. Pookeyhead
    30 Jan 2004
    Don't worry about the GPU for photoshop work at such a low resolution. Anything will do.
    whisperwolf likes this.
  6. mikeyman198
    12 May 2011
    Played around on pcspecialist and ended up with pretty much the same as the Dell, but it had a bigger battery, I'm guessing it will be plugged in most of the time though right?
  7. whisperwolf
    1 Sep 2004
    thanks good to know.
    Yeah it will be plugged in most of the time, I'd checked pcspecialist and found much the same thing, but I could get back let keys with the dell, and dell were also including a copy of elements 9, which would have been a nice upgrade from 7 that I currently use.
  8. mikeyman198
    12 May 2011
    Fair enough, Dell it is :thumb:
  9. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    Are Kepler and Ivy Bridge on the way soon? That might knock the price of the current range of laptops, or you could pick up one of the new ones.
  10. whisperwolf
    1 Sep 2004
    looks like ivy bridge isn't going to OEM's till April, and then it has to filter through to distribution, not really willing to wait that long sans reliable laptop.
