Linux Which Linux is for me?
Discussion in 'Software' started by crazydeep74, 1 Jun 2006.
  1. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Sorry if this has been done a 100 billion trillion * 2 times, BUT! I have some special needs so I feel it necessary I get some real linux users opinions on what I should do.
    At the moment, I'm REALLY big into programming and 3D modeling. These things are important to me. I've found a couple linux distros that seems to catch my attention. One is Xandros, The higher level business and corporate version catch my attention (Flashy box :p, Don't blame me im a linux newb), Of coarse im a cheap ******* so I would have to settle for the Desktop base level version seen Here . Second one is LinSpire Five-0, I think it used to be Lindows, I hear they fixed a lot of bugs, so don't judge from former copies. Third is Novell Suse (Out of the question though, its expensive). Forth is Fedora Core 4/5, Open source, free nice, but really, you get what you pay for. I want a extremely simple setup, Mandrake during my first/second/third/forth install gave me a headache and I never got it installed too! Okay so now lets address what I need this to do for me.
    • Support a NAS (Free nas box with upto 4TB of storage some day (500GB at start)
    • Would be nice if it supports install of AutoDesk Inventor 5, if not a direct install, a network install from my windows server.
    • Need to take advantage of my 250GB HDD
    • Networked
    • Good Firewall (I will possibly setup a smoothwall in the future, but for now this would be nice, I do have a hardware firewall on my router, so do I need a software one?)
    I will test it out on a less power full rig at first, to see if I like it, so good hardware support would be nice. (The test rig is a Pentium CPU (old, 100MHz I assume, 64mb ram, 6gb hdd).
    Thanks.
  2. Glider
    Glider /dev/null
    2 Aug 2005
    So, you're looking for a linux distro that will render you 3D's, act as a NAS (or connect to??), has huge storage space capabilities, is networked (lol, linux = network;)) and had a good firewall... And run on low hardware? Well, every distro will do ;) But the easy ones are certainly Ubuntu and Fedora...
    The low hardware requires a non bloated windowsmanager tough... which will be a bit harder to setup maybe...
    I personally use Gentoo... Not that easy, but not extremely difficult due to portage...
  3. crazydeep74
    25 Jul 2005
    I need it to work with my NAS, Run my 3d rendering programs, ethier off a server or directly from the HDD, dosnt have to have a firewall, but wouldnt hurt. Run on low hardware, dosnt have to run great though.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Oh, access your NAS :) then really any distro will do... 3D render programs (like Blender) run great from Linux distro's...
    if you have some time, I suggest experimenting with Gentoo... You'll probably have to install it 5 times over to get it right, but the gentoo handbook gives you all the pointers you need... And you'll learn a lot about it...
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Another vote for Gentoo.
    If it worked properly with my TV card then I'd b running it right now, it really is fantastic.
    And I love Emerge..
  6. crazydeep74
    25 Jul 2005
    Aside from gentoo, and recommendations for the ones I listed?
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Ubuntu, certainly the easy way to get into linux.
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Ubuntu would be my vote from your list, but if you've got some time to play around try straight Debian. You an set it up, mostly, the same but the apt repositories are better maintained. However gnome is pretty heavy going so once x is installed you can add any window manager, flux would be my vote for a light weight effort and it'll fly on even fairly crap hardware.
  9. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    There's also xubuntu for those of you who want a lighter desktop but an easy install. (Xfce/Ubuntu)
    I'd say Ubuntu if you are new to linux and don't have the time, or gentoo if you have the time to spend tweaking. (read: the first time I installed gentoo, it took me roughly 10 hours over a weekend, but it ran insanely fast on old/cheap hardware)
    As of now, Ubuntu 6.06 runs faster on my year-old AMD 64 laptop with 512MB of ram than XP does on my 6 month old Pentium4 desktop with 1GB of ram.
  10. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Hadn't seent this version before :)
    So when can we expect a fluxbox version :hehe:
  11. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    My ubuntu install is running Flux, Gnome was too heavy for this laptop.
    You can install it with the help of this guide. It's applicable to Breezy, but can probably be easily adapted to Dapper (and other distros).
  12. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    well if you cant get mandrake to install then your going to have problems with installing gentoo from what i have herd
  13. allforcarrie
    allforcarrie Banned
    22 Jul 2005
    my vote. this should run on very low speced systems. It runs great on a 1 gig p3 with 512 meg of ram.
  14. Glider
    Glider /dev/null
    2 Aug 2005
    Hear again... Gentoo now also sports a graphical installer (if you want to)
  15. bender386
    5 Jan 2006
    oh sorry i read this at some stupid time last night. from what i have herd gentoo is the best. if i had time i would try it out. i hate the time absorbing sponge that people call school
  16. crazydeep74
    25 Jul 2005
    Fedora core 5, recommends? Hardware support?
  17. Glider
    Glider /dev/null
    2 Aug 2005
    Gentoo isn't that much of a hassle as people think (even the old fashioned way). I install a working gentoo system (without all the customisation) in less then 3hours on my lappy
  18. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm gonna recommendd Ubuntu as well, after I got EVERYTHING I could ask for working in 4 days, and that's including Guild Wars on an ATi card, the bane of Linux gaming.
