Which Mobo for Pentium D 805
Discussion in 'Hardware' started by ArtificialHero, 11 May 2006.
  1. Guest-16
    Guest-16 Guest
    None of the current ones supposibly support Conroe, although the chipset does the PWM spec has changed which means the boards would have to be redesigned for 975/945 rather than just a BIOS update. So I read.
  2. tecate
    tecate What's a Dremel?
    26 Dec 2003
    Could you please find the link to that board?
    I am in the process of planning my upgrade process and would like to know more about this option.
  3. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    but why is it that on scan that some 975x boards have a cross by crossfire in the technical spec?
  4. koola
    koola Minimodder
    11 Jul 2004
    Not exactly just a bios flash :eyebrow:
    http://www.xtremesystems.org/forums/showthread.php?t=99298
  5. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    yer sorry lol, read up on it a bit more and it does appear lots of modifications will need doing, so as for now i'll buy a good 975i chipset socket 775 mobo
