Displays Which monitor; 1080P @ 144Hz or 1440P at 60/75Hz?
Discussion in 'Hardware' started by TheMadDutchDude, 24 Dec 2016.
  1. TheMadDutchDude
    23 Aug 2013
    Hey guys,
    I'm in the market for a new monitor after having moved to the US a few weeks ago. My rig is with me and is now just lacking a monitor.
    The biggest question I have is whether it is better to go for a 144Hz 1080P monitor for the refresh rate or a higher resolution with a slower refresh rate of 60 or 75Hz.
    Part of me wants the higher resolution but the other part wants the refresh rate.
    The other side note is that I use my Xbox One on it as well.
    Which would you go for? Have you got any specific recommendations to look at? Any help would be greatly appreciated. :)
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
    I have a BENQ XL2420G, I'm really happy with it after having it for for a year and a bit.
    1080p
    144hz
    G-Sync
    1ms (GTG)
    It also has other stuff I played with then forgot about:
    3d vision
    A weird control nob thing
    I honestly love G-Sync, have you considered if FreeSync / G-sync is on your wish list?
  3. TheMadDutchDude
    23 Aug 2013
    If it is 144Hz, G-Sync is on the list. :)
  4. Vault-Tec
    30 Aug 2015
  5. TheMadDutchDude
    23 Aug 2013
    Sadly it's both too large and too pricey for me at the moment. :(
  6. Vault-Tec
    30 Aug 2015
    Aww that sucks. It's not so bad here at £379. With the current exchange rate that should only be about $430 or so.
