Graphics which one of these??
Discussion in 'Hardware' started by Burnout21, 22 Mar 2007.
  1. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i am stuck between to hard rocks at the moment,
    which in terms of speed is better a X1950XT-X or a 8800GTS 320Mb edition
    TBH i dont care about DX10 as i wont be buying or playing any new games for a long time yet.
    £200 mark is my budget on a card.
    ATI R600 cards are out of question.
  2. DougEdey
    5 Jul 2005
    1280x1024 maximum resolution: 8800GTS 320MB
    Anything higher X1950XTX.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Whether you'll buy Vista/DirectX 10 capable games or not, it makes sense to buy a card which uses newer technology, if the price is about the same as the older card :idea:
  4. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I'd say the XTX because I think it performs better?!
  5. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Depends on the resolution, like DougEdgy said, if you don't need higher then 1280x1024 then the 8800 is a better choice, higher resolutions then that and the X1950XTX will have better results.
  6. Burnout21
    9 Sep 2005
    well my res is 1280x1024, and i always thought the 8800 would be faster, but alot of sites are saying the x1950xtx is better.
    TBH a XFX or EVGA 8800GTS 320Mb will be much better than my muppet of a 7600GS!!!
  7. $$OmEGa$$
    $$OmEGa$$ What's a Dremel?
    26 Mar 2007
    I would go for the X1900XT-X, because it performs better, and since you don't care about the DX10 support.
  8. jhk7784
    jhk7784 What's a Dremel?
    24 Mar 2007
    i'd definately go for the 8800GTS TBH. i think it'd be more sensible to go for a newer card since it doesn't make that big a difference imo
  9. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    Hmm this is a tough one. With the release of Stalker it seams that the 320mb on the new GTS's is inadequate. Stalker uses up a huge amount of video ram (over 400mb with maximum textures) so the 512mb xtx is the better card. Meaning that future games will require more video memory that the current crop of 256mb wont handle.
    I think buying a 320mb 8800gts is false ecomony because of the small amout of memory. I just wish the 640mb cards would come down a little more!
    So my verdict is don't buy either. Save a little more for a 8800gts 640mb. It will last you alot longer.
  10. rikbikboo
    rikbikboo What's a Dremel?
    3 Aug 2004
    wait until the 2900 comes out and buy 2 of those. thats what i plan to do anyways :p
    amd x2 6000
    2gb 6400 ram 4,4,4,15
    2x x1950xtx vidcards
    asus mobo
    does the trick for me. see the 3dmark 2006 thread for my results.
    that said i think i would want a dx10 card when it came out (oh i forgot ime getting two)
    although a single x1950xtx will score about 6k 3d marks
  11. Burnout21
    9 Sep 2005
    ummmm i think two ATI x2900xx cards will cost alot more than a 8800GTS 640MB, come to think about it i bet one x2900xx will cost more!!! lol
  12. rikbikboo
    3 Aug 2004
    yeah but if its true to form then a single 2900 will out perform 2 x1950xtx's infact why not go here and see www.fx57.net
    single card 10k plus. there it is on paper :)
    well puter paper
  13. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    8800GTS. But can't you rise the budget and get the 640MB? In higher res, the 320MB sometimes gets out performed by the ATi card.
  14. keir
    keir S p i t F i r e
    5 Oct 2003
    the 8800 for sure :)
