which OS for drivers ?
Discussion in 'General' started by Guest-2867, 7 Oct 2002.
  1. Guest-2867
    Guest-2867 Guest
    hey, i've got my hands on windows xp and was wondering which drivers do i need, i was thinking that windows 2000 compatible drivers should do, or will i need the xp drivers, or will the ones i have be ok ?
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    use the xp ones as you use windows xp, make sense really :)
  3. Guest-2867
    Guest-2867 Guest
    yeah, the thing is, i haven't installed xp yet incase the cd doesn't have my drivers, so i'm d/ling them just in case, so which ones ?
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    the xp ones, xp has drivers for everything anyway. (mostly) :)
  5. Guest-2867
    Guest-2867 Guest
    oh, ok, thanks lazy, i'm just a bit wary because getting the 2000 drivers was a nightmare, :D
  6. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    Lazy....
    Do you think you could find me a working driver for my graphics card for XP then? (it hasn't worked since I migrated from ME to XP... It is a PCI cheapie I use for a 2nd monitor)
    The driver that comes with XP doesn't work?
    Oh, and I think 2000 drivers work with XP though, don't they? But if XP is available get XP?
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    nope :)
  8. Fatboy
    Fatboy Bored
    8 Oct 2001
    just use the Windows dirvers for Standard PCI compatible Graphics Card or whatever.
  9. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    modem drivers are a must as you could be stranded like i was :( doubt you're as stupid as me but best to make sure.
