Other Which OS for NAS?
Discussion in 'Software' started by Kuni D, 3 Feb 2009.
  1. Kuni D
    Kuni D What's a Dremel?
    19 May 2003
    This topic is related to the following thread: NAS for HD content streaming - minimum specs?
    What operating systems should I be looking at for my NAS box?
    I want it to be able to handle drive encryption, drive by drive spin up on demand, mailserver & FTP...and as I'm not great with code/scripting, a nice GUI :D
  2. GoodBytes
    20 Jan 2007
    I never touched a NAS box, I think any OS will do the trick. Although, I have no clue for mailserver and drive by drive spin up on demand. Perhaps Windows Home Server or Windows Server 2008, or Linux as this is what Linux does best... servers. Heck if you just want file sharing than I think Windows Vista 64-bit will be fine.
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    never used it but i hear freenas is very good
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Being a mailserver isn't a normal function for a NAS.
    www.freenas.org - will do most of the things you want except serve mail (there maybe an addon for that but I've never wanted it so havn't looked)
  5. Fumduck
    Fumduck Have torch, will melt.
    5 Aug 2008
    +1 on freeNAS. As soon as I can find some stable legacy hardware in my pile, I will be setting on up at home. Seeing how my other project is on hold waiting for tools. :(
  6. herbs
    herbs Nobody but us chickens
    7 May 2001
    Try Clark Connect but im not sure on the drive encryption side. Openfiler might might the storage side but you might have to hack it for email etc, it's linux based so if your ok with linux then you might be able to do what you want.
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    XP pro stripped down, hassle free in finding software to sort it, and considering all its doing is back up and stream and handle emails i cant see it going wrong at all.
    Its what i am going to be setting up on my shuttle, strip the OS down to its bare essentials and i can add-on apps as i need them. I did consider a linux distro like FreeNAS but after looking at it i came to two conclusions, one i dont understand linux well enough to drive it, and two i considered it to be limited in terms of adding features which looped me around to the first point.
    FreeNAS is well documented and i am sure a dummy could follow there guides in setting it up, but when you want extra features it gets messy.
  8. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    Another vote for FreeNAS. works great even on low powered machines, and the browser-based user interface is very sleek.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    Debian all the way ;)
  10. Matticus
    Matticus ...
    23 Feb 2008
    Not to hijack this thread, but how well does freeNAS do printer sharing?
    I have set up an ubuntu server/nas and apart from the occasionally issue with folder passwords, printing is giving me a huge headache.
    So perhaps freeNAS could help me out.
  11. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    I'm personally rather fond of using NetBSD for server tasks. You can really strip it down and customize it. If you don't like to tinker that much, FreeNAS or similar would probably do the job as well :)
  12. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I'm using Ubuntu myself (wanted the GUI so I can use it as a basic machine when I dont fancy booting up the main rig) on an Atom 1.6Ghz, 1GB ram.
    Runs SMB for file sharing, Bind9 for caching DNS (my ISP's dns are terrible!), DHCP, Left 4 Dead Dedicated server and a couple of other bits and bobs including a TeamSpeak Server.
    As such I would say any *nix environment would serve you well :)
  13. Glider
    Glider /dev/null
    2 Aug 2005
  14. Matticus
    Matticus ...
    23 Feb 2008
    Yeah I had it set up, and it would print test pages from the windows machines but not anything useful.
    I tried freenas knowing that I wouldn't be able to get a print server working without installing my own packages, but if I ever need a pure NAS again I will be using it as it was dead easy and worked like a charm.
    I am currently using Clark Connect for my file and printer server, again had some printer issues (I think my printer hates linux) but now it is working 100% and apart from the printer issue and adding a new hard drive afterwards, it was all done in the web based gui and took no time at all.
    So my recommendation is, if you want a NAS, use freeNAS, if you want multi purpose (print/web/file/email) server then go for clark connect, but grab yourself putty and winscp as remote command file and file browsing is a godsend when tweaking and fixing.
