Linux which os.
Discussion in 'Software' started by Pballer98c, 11 Mar 2005.
  1. Pballer98c
    Pballer98c Minimodder
    2 Jan 2005
    so i now have a pentium 4 1.4ghx w/ 286mb of ram just sitting here folding away on winxp home. i would like to play around with either osx or linux, but not sure which or maybe even others (solaris?). the computer doesnt really do anything except fold, just would like something to play around with. any sugguestions?
    thanks guys
  2. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    OSX wont run on a Pentium 4 you need a mac and Solaris will cost a fortune. Linux is probably the best option to go. I hear Ubuntu is doing quite well. I use Gentoo but I wouldnt recomend it for learning how to use linux
  3. Pballer98c
    2 Jan 2005
    well with osx i was thinking on using the new cherry os. that would make it run on a pc, correct? thanks for the input
  4. polus
    polus What's a Dremel?
    7 Aug 2004
    Have you considered FreeBSD ?
  5. simon w
    simon w What's a Dremel?
    3 Nov 2003
    I thought Solaris was free for some reason :confused:
  6. painesy
    painesy What's a Dremel?
    28 Apr 2004
    Solaris is free.
    You just have to pay for any support.
  7. macdude425
    macdude425 What's a Dremel?
    13 Mar 2005
    Say what?
  8. Ben
    Ben What's a Dremel?
    11 Aug 2003
    http://forums.bit-tech.net/showthread.php?t=85165&page=1
  9. Lynx
    24 Nov 2001
    Or you could use PearPC which is free and is not breaching multiple copyright laws. CherryOS is a direct copy of PearPC with multiple breaches of the GPL and they probably are about to get sued horribly
  10. trigger
    trigger Procrastinator
    22 Mar 2004
    CherryOS is an evil rip off of PearPC which allows you to run OSX on a PC.
    Solaris is free, but support costs $$$
    Linux is teh 1337
    Windows is easy
    *BSD is secure (although security of course depends on an admin with a clue) and fun.
    OS/2 is ... well you get the idea.
    ... at the end of the day an OS is just a tool, so you should choose an OS that does what you need well. If the PC is going to be just folding and maybe serving up some files, then Linux would probably be best. For a router I'd go with OpenBSD.
  11. Go4t
    Go4t i
    13 Dec 2003
    cherryOS was a complete ripoff of pearpc but its supposed to run quite a bit better
    i know a woman that still uses OS/2 as her main operating system :wallbash:
    (she looks like bob from fight club too :worried: )
