Graphics Which PCI-E slots for SLI?
Discussion in 'Hardware' started by Kronos, 28 Feb 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    The top and bottom slots! :thumb:
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I thought as much which is good as more space between then makes for better airflow I would have thought.
    Cheers Glenn.
  4. faugusztin
    11 Aug 2008
    What ? The first and third slot are running at PCI-E 3.0 x8 when SLI. The fourth slot runs at PCI-E 2.0 x4 ! And the second slot (x1) slot runs of course at 2.0 x1.
  5. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Taken directly from your mobo manual:
    B. Connecting the Graphics Cards
    Step 1: Observe the steps in "1-5 Installing an Expansion Card" and install two CrossFireX/SLI graphics cards on the PCIEX16 and PCIEX8 slots.
    Step 2: Insert the CrossFireX(Note)/SLI bridge connectors in the CrossFireX/SLI gold edge connectors on top of the cards.
    Step 3: Plug the display cable into the graphics card on the PCIEX16 slot
    So, Blogins is right. Top and bottom.
  6. faugusztin
    11 Aug 2008
    Ah yes, Gigabyte went full retard in specification and their specification order don't match the physical order. I apologize.
  7. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    At least Gigabyte wired the board so you get a nice gap. All things that they never used to bother with.
