Photos Which photo is better?
Discussion in 'Photography, Art & Design' started by Synay, 19 Sep 2010.
Which version do you prefer?
  1. Black and white
    54 vote(s)
    91.5%
  2. Sepia
    5 vote(s)
    8.5%
  1. Synay
    Synay What's a Dremel?
    25 Oct 2009
    As in the title, which photo do you think is better? Posting poll for ease of use.
    Thanks for watching and the votes. Critics welcomed as well :)
  2. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    I can't exactly explain why, but the B&W seems more pleasant to my eyes.
    On a side note, Sennheiser for the WIN! :rock:
  3. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    B&W - it looks crisper and more modern which fits with the item being photographed. Older style headphones may have looked better in Sepia...
  4. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    B&W definitely
  5. LatinSpirit
    LatinSpirit Minimodder
    23 Apr 2009
    Spot on! Sepia makes them look old so B&W gets my vote too
  6. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    B&W, also because of the fact that the Sennheiser are black always, not brown-ish. Having the picture in B&W makes it feel as if it was real.
  7. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Neither. They both look like the effect was applied in camera. Maybe I'm just fussy. If it was do or die; fine - not the sepia.
  8. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    The Black and white.
    The sepia shot just doesn't LOOK like sepia in this photo.. If you can understand what i mean?
    Kinda makes the shot look "cheap" in my opinion
  9. QuietlyConfident
    QuietlyConfident What's a Dremel?
    14 Jun 2009
    I prefer the sepia, but echoing previous commentors; it doesn't look like sepia. But even so, I like how it brings out the warm colours. B&W always seems to be so dull unless it has high contrast, IMHO.
  10. Wingtale
    Wingtale What's a Dremel?
    29 May 2010
    Like most other people.
    I think the black and white is more attracting.
    The sepia reminds me of cr4p
  11. Pookeyhead
    30 Jan 2004
    I think it would probably be better in colour. I can think of no reason for having it black and white at all.
  12. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Gone for BW
    however i think Pink and yellow would look best
  13. Pookeyhead
    30 Jan 2004
    It's a contemporary product. Why B&W? I'm always sceptical of the use of B&W. I've nothing against it if it's in context, but I can't help but think this has been done for for no particular reason... just for the want of something different to do to it.
  14. GrueBoy
    GrueBoy What's a Dremel?
    26 Nov 2010
    The black and white one is better - but only just.........
  15. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Definitely the B&W, but I think that is specific to this subject rather than a global impression.
    I have a theory that says that any suitably large black and white print will look like art to most people.
    Some day I plan to test this theory by taking the worst picture I can find, printing it in B&W in 20x30" size and framing it nicely and see if someone is dumb enough to buy it.
  16. Jipa
    5 Feb 2004
    BW. I'm allergic to the piss-yellow light of incandescent lamps, and the "sepia" to me seems like you just took a quick shot under light bulbs and the white balance ended up yellow.
  17. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    +1 :)
  18. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Neither work for a product shot,
    -The background needs to be white, maybe place it on some perspex to add some base reflections rather then the harsh shadow.
    -Rotate the headphones slighty so that you get the whole of the brand name in, the end of Sennheiser is out of your DOF.
    -Get the epxosure right in cam and you don't have to worry later.
    Then you can play around in LR/CS4/BLAH but as its a modern product it wants to be in colour, give it a white background will help it pop.
    IMO.
  19. Boldar
    Boldar Minimodder
    24 Feb 2003
    Well I like the Black & White one although the sepia one has a certain quality. but which one is best?
    There's only one way to find out ..... FIGHT!!!!
  20. Guinevere
    Guinevere Mega Mom
    8 May 2010
    What's the photo for? I don't think it's an image that needed a B&W or sepia "effect" process at all. Not with a product that is primarily B&W to start with.
    I like the lighting, but I feel it could have been improved by:
    - Not having the cans twisted, they should face each other
    - In a narrow DOF image, the point of focus should be on something important. At the centre of yours is a the blank part of the band.
    - The brand name looks too tightly cropped.
    - The base isn't clean enough (Is that a hair?)
    - The headphones are dusty (Easy to fix in post)
    - The shadow to the rear on right (Base meets background) is distracting. It could easily be shopped out
    - The cable could be shopped out, as long as you're not seeing the attachment grommet you could get away with the cable being missing (as long as it doesn't appear to break the laws of physics)
