which processor 2500+barton or 2600+t'bred
Discussion in 'Hardware' started by Dodge, 25 Feb 2004.
  1. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    done a bit of research into this, but i cant decide what to do. should i go for a 2500+ barton or 2600 t'bird, or maybe a 2600+ barton.
    is clock speed beter than cache is what i am asking
  2. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Barton
    'doc
  3. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    well the barton 2500+ is 1.830 and the 2600+ tbred is 2.130. you won't see the difference. the barton 2500+ is known as a good overclocker and people tends to use it due to his 333 fsb and 512k cache.
    presonally I would take the barton 2500+ cause you can easily overclock it to 2.4-2.5.
  4. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    The bartons in general are much nicer. If youre overclocking then look for an unlocked one second hand.
  5. Murdoc
    25 Jul 2003
    I said this to dave on msn, he doesnt trust my amazing superior knollege thou :worried: hehe.
    'doc
  6. Tim S
    Tim S OG
    8 Nov 2001
    get the barton, more cache = more performance, and they've been clocking to similar speeds as a Tbred B...
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    2500 will prb be better... with some 3200 ram almost all do 3200 speeds on stock voltage.. simply increase the FSB to 200 and voila.
  8. Dodge
    10 Oct 2003
    one thing about overclocking, i guess that i will end up getting one of these super locked bartons, has anyone found a way of unlocking it yet???
    the only method i saw was to join one chach together and to break another appart. are all amd pocessors now locked in the same way (unless u get a unlcoked one)
