CPU Which Q6600?
Discussion in 'Hardware' started by antec900, 18 Aug 2010.
  1. antec900
    antec900 Minimodder
    11 May 2009
    I'm looking to buy an Intel core 2 quad 6600 processor....
    I was just wondering if there was any specific type i should get. I'm kinda confused because i was told that there are more than one version of q6600 such as a GO stepping core?
    Can someone please explain to me whether it matters which version i buy, if there even is different versions lol.
    Sorry I'm a bit confused...
  2. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    The G0 is the newer stepping core of the Q6600, as opposed to the original B3. This link to the Intel site shows that the main difference is a higher limit to the T case.
    In performance terms, the G0 is a better overclocker than the B3; but I would assume all Q6600's for sale would be G0 by now.
  3. Siberdine
    Siberdine Safety Not Guaranteed.
    1 Aug 2010
    G0 is the newer stepping of the Q6600's, and it gives off less heat. It doesn't make a huge difference to people who don't overclock, but it's still worth getting. I agree with klutch, at this point all Q6600's should be G0 stepping, if they aren't, you're being being ripped off in a sense.
  4. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    in IDLE im around 35c at 3.2Ghz with the G0 Stepping. One of the Sannin CPUs, the Legendary ^^
  5. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    Whats the diffrence between this and an i5??
  6. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    The G0 for sure. Better overclocker, and generally lower VIDs as well as lower voltages on overclocks, so it'll run cooler as well :)
    The Q6600 is an older model of the Core 2 era, that runs in a LGA775 socket. The i5 series are new chips, running in Socket 1156.
  7. chrispy61
    29 Jan 2010
    Thanks :thumb:
  8. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Might be worth checking out this site. It lets you compare CPUs quickly and easily.
    The dual core E8400 and E8600 score really well (dual core)
    http://www.anandtech.com/bench/CPU/2
