Small Form Factor Which Shuttle for me!
Discussion in 'Hardware' started by drazhar, 29 Sep 2009.
  1. drazhar
    drazhar What's a Dremel?
    29 Sep 2009
    I have the following bits lying about
    1 Core 2 Duo (Old one, LGA665)
    1 BFG 8800GT 512MB
    2GB Generic Ram
    I have my eye on some b-grade shuttles
    SD39P2 @ €269
    SD37P2 @ € 249.00
    SP35P2 @ € 169
    This will be used behind my TV for movies and a spot of very mild gaming (read Sims3 for the better half)
    What should i buy? There are no alternatives, it will be one on the above. Obviously i'd prefer the cheapest option, but if there are issues, please, let me know
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    SP35P2 is what I had, it's pretty loud stock but definitely very good. The PSU is amazingly awesome..
    No experience with the others, try asking the Sudhian forums, they know a lot more about Shuttle PCs than Bit on average.
  3. Tyr
    Tyr Minimodder
    7 Jun 2006
    Personally if I went for a shuttle one of my major concerns would be whether a dual slot GPU could fit. Even something like the 4770 is dual slot and that type of cooler is getting more popular (and you have an 8800 spare).
    That is the biggest problem with the latest shuttle cases.
  4. docodine
    10 Feb 2007
    You can easily get something the size of a 4870 1GB into the SP35P2, so I wouldn't worry too much about it. IIRC someone on Sudhian actually got a GTX 295 to fit snugly in the same case.
  5. drazhar
    29 Sep 2009
    Ok, loudness is an issue. It is going to be sitting behind my TV so i dont want it to be very loud! Is it merely the fans that are a bit pants (would replace with some tasty Sharkoon's if that is the case, or what?
    Im not worried about dual slot GPU, even though i'm almost certain that this case takes them. The BFG 8800 GT is single slot, the way a GFX card should be!! :)
    Anyone got any thoughts on a good, quiet, shuttle model?
  6. docodine
    10 Feb 2007
    All of the fans are pretty bad, I replaced them all besides the PSU fan on mine and it was still pretty loud. PSU fan would take soldering, which I'm too squeamish to do inside of a power supply..
    I would direct you toward a Micro-ATX case in the same form factor of the Shuttle ones, like the Lian Li (even though they're bigger).
  7. drazhar
    29 Sep 2009
    Hmmm, thats all well and good, but i dont want to have to buy a MoBo, HSF, etc. I have the couple of parts lying around, and i just needed a shuttle to slot them into! :) Will have to think about it some more
  8. docodine
    10 Feb 2007
    Look at the newer Shuttle cases then, not the P2 chassis, the H7s.
