Modding which software touse for CAD design?
Discussion in 'Modding' started by PurE GaminG, 2 May 2013.
  1. PurE GaminG
    PurE GaminG New Member
    24 Feb 2012
    hey modders
    just quick qestion, ive been told to create cad for my deisgn so that the company could use for thier router machine to cut the acrylic. problem is which software do i use .
    i have photoshop cs6 could i i use that and covert it to cad file?.
    or do i need a deadicated cad software.
    thanks
    if you need more info please ask
  2. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I always use Autodesk AutoCAD to create the files for laser cutting. It's by far the best software for creating 2D plans.
    If you're a student you can gain free access to all of Autodesk's software here.
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    Our lasercutter accepts vector images as input, so we use (free & open source) inkscape. I don't know about theirs, however
  4. Cheapskate
    13 May 2007
    http://www.freebyte.com/cad/cad.htm
    A graphic design-based program like Illustrator probably won't work. Find out what file types they prefer/need and work from there.
    If you drew the original design in Sketchup, there's a dxf exporter plugin that does a great job with flattened objects. It will need to be re- drawn in a proper cad program to get real arcs and such. -I find tracing SU dxfs goes faster than drawing from scratch in a cad software, though.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    A "free as in beer" AutoCAD clone is "Draftsight" from Dassault Systeme - it runs on Windows, Mac or Linux.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Double post, ignore this.
