Storage Which SSD for PS3?
Discussion in 'Hardware' started by 51lver, 18 Oct 2010.
  1. 51lver
    51lver Forever Hungry
    31 Aug 2009
    Got PS3, games and loads of cash for birthday, but wanna get SDD for the PS3 but dont know which one to get?
  2. DragunovHUN
    DragunovHUN I want to change my name but I also don't
    30 Oct 2008
    Nice sentence there, buddy. I don't think it's worth it.
  3. brighty22
    brighty22 New Member
    19 Aug 2010
    it isn't. you're much better getting a 500GB SATA :/
  4. DarrenH
    DarrenH New Member
    12 May 2010
    Depends on how much storage space you need?
    I'd wait for the prices to drop for another 6 months or so at least. You will need minimum 128GB depending on your usage and ideally 256MB. These are way to expensive to make any real difference. Most PS3-specific games are optimised to run off the Blu-Ray and others combine with the hard Disk when an install is required.
    They are made to run on any PS3 and display the same. Loading times may be quicker on certain games but when playing you won't notice the difference at all. I just upgraded my HDD instead to a 7,200 speed and bigger capacity.
    But pretty much any SSD (I'm sure you meant SSD and not SDD) will work in the PS3 if you really want to go ahead.
  5. jrs77
    jrs77 Well-Known Member
    17 Feb 2006
  6. 51lver
    31 Aug 2009
    Thanks guys. I stick with normal HDD, but which 1 not very clued up on them
