Cooling Which TIM paste and how to apply it to CPU?
Discussion in 'Hardware' started by giskard, 1 Dec 2021.
  1. giskard
    giskard System builder
    21 Nov 2009
    For my last build over a decade ago I used Arctic Silver 5 TIM paste (I still have some left, probably gone off by now) and applied it as a narrow strip across the centre of the CPU, then clamped down the cooler. Seemed to work fine but that CPU is a fair bit smaller than the Ryzen 5900X I'll be building with. I've looked looked at the bit-tech article on this but judging by the comments, it's not necessarily the best way to apply and spread the TIM.
    Anyway, what's the current recommendation for TIM paste? The cooler will be a Noctua NH-D15 chromax.black which comes with a 3.5g tube of Noctua's NT-H1 paste. Is that any good for the 5900X or should I use something else? Also, what about TIM cleaner? Any recommendations? I've seen the 2 bottle ArtiClean stuff or there are wipes from Akasa and Noctua.
    Finally, what's the best way to apply the stuff? Do the surfaces of the cooler heat spreader and of the CPU need to be pre-treated or cleaned before applying the paste?
    EDIT: added Artic Silver Thermal Compound application method guide - looks like a useful document
  2. Gareth Halfacree
    4 Dec 2007
    I've a 2700X, and I used Noctua... something. Maybe NT-H1, maybe not. I forget. Applied it the same way I've always applied it: using a business card to spread a thin layer evenly over the heatspreader. Takes a little longer than the pea method, maybe, but it's ever so satisfying.
    I cleaned the stock stuff off the heatsink with isopropyl alcohol, 'cos I've always got that stuff to hand. Works a treat.
    EDIT:
    Ah, yes, it was NT-H1. It's been installed since late March 2019, never given me a moment's trouble.
    giskard likes this.
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    The horrible truth about thermal pastes... is that they're basically all fine. Noctua's in the box paste is fine, I've used a NH-D14 for years and switched to Thermal Grizzly only because I lost the tube.
    For cleaning it's another vote for Isopropyl Alcohol, it's cheap and it works. If the cooler and CPU are new there should be no need to pre-clean the surface, if they're second hand they'll only need cleaning if there's old paste or some other crud present.
    For application I put a blob in the middle and squish it with the contact plate. Everybody seems to have there own way of doing this bit, it's always worked for me.
  4. adidan
    25 Mar 2009
    I've found this to be very true.
    Also I've tried the X line, blob, spreading and over gooping and found it makes little to no difference whatsoever
    So long as you have enough and a good contact with the cooler you're good
    Clean with isopropyl alcohol. With my Ryzen I think I did a combo blob mini spread or cross, can't remember (just because the layout of the CPU).
    Yeah the noctua goop will be fine.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Isopropyl alcohol and then MX4 for me(only because of its no conductive properties) with a credit card. The little loyalty cards you get to go on your keyring are ideal due to there size.
    As said before they are all pretty much the same unless your getting into extreme overclocking and 0.1 of a degree really matters.
    Mr_Mistoffelees likes this.
  6. Big Elf
    23 Apr 2009
    IPA and MX-2 usually for desktops/NUCs. I've tried loads over the years and nearly went to MX-4 but MX-2 is the best to apply for me and there's only a few degrees difference between the ones I've tried apart from Liquid Metal.
    IPA and Liquid Metal for laptops
    LennyRhys likes this.
  7. Sgoaty
    Sgoaty Minimodder
    4 Feb 2005
  8. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Exactly what I did with my recent CPU upgrade.
  9. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Only thing with that is liquid metal can have a habit of flowing ocasionally, I know Asus made a gasket for their laptops, so something to keep in mind.
    But just to say whateveryone else has, everything is basically fine these days. Even cheese slices are 'fine' as they're better than air, but all proper TIM will be withing a 10C range, which will be fine seeing as OC'ing is basically dead these days. The only times it matters is when you need non conductive ones, or to do funky things like lateral conduction with graphine sheets (I've seen them used as funky heatspeaders, and could potentially be useful for fixing Intels heat concentration problems), but I digress. That Noctua stuff is regarded as one of the bests.
    giskard likes this.
  10. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Pretty much the same opinion as the consensus here, in that it doesn't really matter that much. Gamers nexus did a piece on the different application methods and found that as long as you use enough, that doesn't matter either.
    I prefer to spread the paste on the IHS because I know then that every bit is covered and gives me a warm fuzzy feeling inside.
    I use thermal grizzly kryonaut because "it's the best" or rather has the highest W/mK rating of non conductive pastes, and while again it gives me untold pleasure in that knowledge, deep down I know it makes bugger all difference. It's also very thick and a pig to spread. I'm more than happy to use most of the bundled pastes that come with coolers, other than the stuff that's pre-applied to coolers. Don't know why but I just don't like it.
    giskard likes this.
  11. Yaka
    Yaka Modder
    26 Jun 2005
    all these i have just said meh and do a X with some dots in the spaces between.
    giskard likes this.
  12. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    I use Thermal Grizzly.
    I remember a way of doing this years ago in Custom PC I still use.
    Blob in the middle, then index finger covered in cling film and gently spread across the entire IHS.
