Cooling Which Triple Rad should i buy?
Discussion in 'Hardware' started by jopers1986, 11 Oct 2005.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
  2. Marvt74
    Marvt74 What's a Dremel?
    29 Mar 2004
    I'd go for the PA120.3 if i was after a new one. Looks like they'll be the best of the bunch
  3. Nexxo
    23 Oct 2001
    The first three are pretty much the same in performance, so aesthetics would be your only reason for choosing one over the other. The Aquacomputer Evo is for small bore systems specifically, and a good performer.
    However if you are going small bore, the HTF3 Tripple X by Watercool.de is your rad of choice. It has nine metres worth of tubing wrapped up in it, and tests show it delivers spectacular cooling performance.
  4. Marvt74
    29 Mar 2004
    I was under the impression thr Thermochill PA120.3 was better than the others as its the new design over the old he120.3 model
  5. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'd say a BIX3 :)
  6. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    thermochill, as it can now be used with very quiet fans at a good performance.
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    thermochill too.. co-designed by Cathar of LRWW fame.. so who's gonna argue with him?
  8. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Thermochill here ;)
  9. koola
    koola Minimodder
    11 Jul 2004
    Gotta be a BIX.3 :D
  10. PHILIP1193
    PHILIP1193 a Self Confessed HP Server Lover!!
    8 Dec 2004
    thermochill, co-designed with cathar, who is a ledgend, teh new pa version not teh he version has less dense fins but it a bit thicker and hence is better with less high performance fans and more friendly with low noise fans which eveidently produce less cfm's
    Phil
  11. Leeum
    16 Feb 2004
    Don't you mean more CFM's? :eyebrow:
  12. Nexxo
    23 Oct 2001
    No, he means fewer CFM.
    Let me drop in the grammar and punctuation for you and all will become clear... :)
  13. jopers1986
    7 Jan 2005
    right, well i ordered a BIP3, as my case is TINY, so the tinest one is best!
    thanks for your help
