Motors Which tyres to get under £60 a piece.
Discussion in 'General' started by Neoki, 21 Aug 2006.
  1. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hello, I have a corsa c 1.2 sxi twinport and it currently has some pirelli p6000 185/55 15 H and would like to know if there is any better hardwearing but "performance tyres" out there.
    Thanks in Advance.
  2. mushky
    mushky gimme snails
    24 Mar 2003
    P6000s are a good choice IMO
  3. Neoki
    Neoki Minimodder
    26 Oct 2004
    finally a reply. Thanks man. Would there be any others.
  4. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    I'm not keen on P6000's, great tire in the dry but a bit of a ditchfinder in the wet.
    Goodyear EAGLE F1's aren't bad but wear a bit fast imho.
    I have Toyo PROXES T1-R's and they have seen me pretty well tbh.
    I can't help but think is it really worth £240 for new boots for a 1.2?
  5. Neoki
    Neoki Minimodder
    26 Oct 2004
    The p6000's are £50 a piece so thats why i like them.
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    My mate gets 195/something R15 eagle f1's for around £50 each.
    And yeah they're worth it for the stopping and turning ability.
  7. Neoki
    Neoki Minimodder
    26 Oct 2004
    where from. Ill have to have a look at these.
  8. Xen0phobiak
    8 Aug 2002
    Local place, but try blackcircles or easytyres online.
  9. Neoki
    Neoki Minimodder
    26 Oct 2004
    Well theres many types of this tyre so wat one is the best as theres GOODYEAR EAGLE F1 GSD2 as well as GOODYEAR EAGLE F1 GSD3 and plain gs'
  10. Xen0phobiak
    8 Aug 2002
    GSD3 is the latest, I run GSD2 as theyre the only ones they do in a size that fits my wheels.
  11. Neoki
    Neoki Minimodder
    26 Oct 2004
    The gs looks better then the gs-d3
    [​IMG] [​IMG]
  12. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Another vote for the Eagle F1s. They grip like a m****rf****r tbh.
  13. Xen0phobiak
    8 Aug 2002
    Testicles.
  14. Neoki
    Neoki Minimodder
    26 Oct 2004
    wtf
  15. NiHiLiST
    18 Aug 2001
    I agree ;)
  16. mushky
    mushky gimme snails
    24 Mar 2003
    Eagle F1s are great but they are going to cost you a bit more. If you can spare the extra then go for it but I'm not sure how noticable the difference would be on your car, I'm guessing not a great deal. It is your money :) Stay away from Toyos if you want hard wearing tyres.
  17. Xen0phobiak
    8 Aug 2002
    I completely disagree with the "small engine doesnt need good tyres" mentality. If someone in an 'underpowered' car wants to go somewhere fast they have to carry speed through turns etc.. rather a more powerful car which can speed up at will, so I'd actually say there's more of a need for decent tyres.
  18. mushky
    mushky gimme snails
    24 Mar 2003
    No one recommended any tyres that aren't good.
  19. grungedead
    grungedead Minimodder
    8 Dec 2005
    i have eagle f1's on my golf, i believe the tyres are 16x8 so they are pretty wide.
    grip is phenomonal even in the wet, also had 2 nails in one tyre and it didnt even go flat (even slightly) only noticed when i changed the suspension... mr kwik fit sorted the tyre tho :)
    edit: if yor going to spend 240 on tyres youd get better hadling by going for new wider alloys, you can pick em up off ebay usually with decent tyres with 4mm tread left for just shy of 200 quid. and you could sell your old rims and tyres and make alot of the money back...
  20. Neoki
    Neoki Minimodder
    26 Oct 2004
    What are these like for hard wearing though.
