Portable Which Ultrabook (UK)
Discussion in 'Hardware' started by N4N01D, 1 Nov 2013.
  1. N4N01D
    N4N01D New Member
    29 Apr 2004
    Hi,
    If you had the following requirements, which Ultrabook or very light portable laptop would you buy?
    Fast Processor (Ideally i7 Processor)
    8GB Memory
    256GB SSD
    15" Screen (though could do 13.3")
    Can do dual screen (with a docking station)
    Very Portable
    Windows 8.1 (i.e. not Macbook Air)
    Money isnt really an problem as these will be given out to corp users.
    So if it was you, which would you go for?
  2. kissinger
    kissinger Member
    6 Dec 2011
    Sony Vaio Pro 13 hands down.
    I'm getting one myself when a good deal comes up. Up until very recently they were offering a free upgrade to a 256GB PCIe SSD. If that comes back around I might bite.
    Only thing you've got to look out for is there were some owners dealing with poor WiFi and some problems with the front bezel, but I think they are fixed now.
  3. GoodBytes
    20 Jan 2007
    Are you interested in a digitize pen (the good pen technology), to write notes, graphs, diagram, and well draw?
    Is it for school? work? What do you plan in doing with the system, I mean what kind of tasks?
    I don't like the Sony Vaio Pro 13.
    -> not great quality.. feels flimsy
    -> You need to open the screen lid, which will lift the back of the laptop, to give you room to plug the expendable Ethernet, or any USB flash drive, meaning if you close the lid and have thing connected it will put pressure on the ports.
  4. phinix
    phinix RIP Waynio...
    28 Apr 2006
    XPS 13 ultrabook!
  5. hakank
    hakank New Member
    28 Oct 2013
    Lenovo do some great ultrabooks, you should check them out
  6. kissinger
    kissinger Member
    6 Dec 2011
    I can't understand your second point, but if it feels flimsy it's because of the carbon fibre body. They could have made it aluminium like a MBP but then it would be as heavy as a MBP ;D
  7. GoodBytes
    20 Jan 2007
    When you lift the screen, the laptop lifts from the table. This is required to plug things thick on the ports on the side.
  8. kissinger
    kissinger Member
    6 Dec 2011
    Still can't understand what you are saying.
  9. droyden
    droyden New Member
    6 Sep 2011
    We have just obtained the new dell latitude e7440, very nice 14", i7, 256gb ssd, 8gb. Much more robust than the older e series, which we ditched. 1.7kg but solid like the old d series. The xps 13 is also a nice laptop and is actually an ultrabook. The advantage of the latitude is that you can get a docking station for it, which may or may not be a requirement
  10. faugusztin
    11 Aug 2008
    Keep in mind, ultrabook and fast processor are requirements from opposite end of the spectrum. While ULV CPU has acceptable speed, they are nowhere near the quickest options on the market.
    The difference between i3 ULV, i5 ULV and i7 ULV is minimal - frequency, cache, no Turbo for i3. That is it - all are dualcore with Hyperthreading with base freqency around 1.4-2GHz.
    Same applies for normal mobile i3/i5/i7, just the frequency jumps are bigger - still only dualcore with Hyperthreading.
    The only "fast" processors are the quadcores (they have Q in the CPU name), but those are not suitable for ultrabooks, because they have TDP of 35W or higher! Ultrabook definition allows only 17W (<=Ivy Bridge) or 11.5/15W (Haswell) CPU TDP.
    http://en.wikipedia.org/wiki/Haswell_(microarchitecture)#Mobile_processors
  11. fdbh96
    fdbh96 New Member
    29 May 2011
  12. N4N01D
    N4N01D New Member
    29 Apr 2004
    Thanks guys, I'll definitely take a look at that new XPS15 and the Vaio as they look to tick most of the boxes!
