Xbox 360 Which USB wifi adaptors work with the 360?
Discussion in 'Gaming' started by GreatOldOne, 15 Jun 2007.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Apart from the obvious, over expensive MS one, that is.
    I've got my 360 currently plugged into an ethernet wireless bridge, but that's need elsewhere soon - so I thought an inexpensive USB dongle would do to replace it. But which one?
    Ta,
    GOO
  2. atanum141
    22 Jul 2004
    Is your 360 near your PC Goo?
    EDIT: ooh also no USB AP's work with the 360, only Bridges work and the expensive M$ option. The old Original xbox wireless bridge works with the 360, they can be had from Ebay.
  3. Veles
    Veles DUR HUR
    18 Nov 2005
    No idea which specific ones work with the 360 but I hear the majority of dongles work. Don't quote me on that though :p
  4. atanum141
    22 Jul 2004
    No Access Points work, what people need are bridges.
  5. DougEdey
    5 Jul 2005
    Look here, £70 for the dongle inc. 12 month subscription.
  6. mushky
    mushky gimme snails
    24 Mar 2003
    any cheapo bridge should work. As long as it's working on TCP/IP and not USB then it should be fine. i.e. something with a network port instead of a USB port.
  7. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    Well I had a netgear wireless network bridge that worked perfectly with my XBox but the 360 refused to use it. I dont know if the 360 firmware updates have fixed it or what. I can try again if you want me to. Just a heads up.
