Displays Which way is better?
Discussion in 'Hardware' started by MSHunter, 23 Jun 2011.
  1. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Hi,
    I have two cheap dell 15-17 inch displays at work running off a cheap 460 (MSI I think the one with the really small aluminium cooler)
    I am pretty sure the Dell's are VGA only.
    Now the question is will I get a better picture (for work)
    with one over the DVI (DVI adaptor) and one over the VGA
    or
    Both over the two DVI sockets using two DVI-to-VGA adaptors?
    Oh yeah and we are not allowed to update drivers because a guy fried one of the cards that way. remember the run away heat issue a few months back?
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    If the monitor are VGA only... you can't improve the picture quality by changing the way it's connected, it will still be connected the same way.
