Networks Which Wired Router
Discussion in 'Hardware' started by LeMaltor, 26 Oct 2011.
  1. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I need a wired router, I don't really want to spend more than £30-50 but I have no idea about which to get as I have never had one before or even if my budget is realistic.
    I absolutly don't want a wireless one or one that even does wireless, as I don't want even the remote possibility of anyone DLing things they shouldn't off it.
    I have Virgin cable BB and live in the UK, I need the conn to share between 4 comps, but 5 would be better so I can just stick the PS3 on it too.
    Thanks for any help :thumb:
    edit: Or can I get away with just a switch? I don't know what they are either >_<
  2. Jeevus
    Jeevus Minimodder
    6 Sep 2009
    Do you have the older separate modem and router or the Superhub (all-in-one)?
  3. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I have the modem, goes from modem to comp at moment. Theres a big distance between the two as well, my comps are no where near my modem, thats downstairs, comps are upstairs. No good with the superhub splitting the conn downstairs then having to run 5 wires upstairs.
    I just want to run one wire up here and split it in the comp room.
  4. Jeevus
    Jeevus Minimodder
    6 Sep 2009
  5. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    check the b-tech market place they had a 100Mb one going for around 13 I think :)
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I agree a basic Xport gigabit switch would be more ideal for your application. Since most modems these days are actually 1port routers, there is no reason to get an additional router for wired. You end up using it as a switch anyway since you must disable a 2nd routers dhcp server etc. Switches are also about half the price and are often available in much more robust metal enclosures. The one linked by Jeevus is a good example. Others I have personal good experience with are trendnet (often cheaper than netgear and just as good) and HP (though mostly over the top and likely out of budget).
  7. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Watch out though. If the modem assigns the computer directly linked to it an address not similar to 192.168.*.*, 172.16.*.*, or 10.*.*.*, then you need a router connected to the modem. A switch simply gives the modem multiple connections - which means that your ISP would need to give out separate IPs for each connected computer. Which is impossible. So a router connects to the modem, and then switches extend the functionality of the router. Of course, if the modem does give out a private IP address on the inside, then all you need is a switch. Somehow I doubt it though.
  8. phuzz
    phuzz This is a title
    28 May 2004
    I picked up a Dlink 8 port Gb switch for about £15 on ebay a few years ago and it's done me proud.
    However, if you only need to share internet around then 100Mb is fine, Gb comes into it's own if you're transfering files around, or streaming files.
  9. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I've ordered a very cheap router, it should come tomorrow, I will report back if it works or not.
