Networks Which wireless router do you use?
Discussion in 'Hardware' started by gcwebbyuk, 6 Mar 2011.
  1. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    As the title says...
    I have a Belkin F5D8635-4v1 - and am having lots of issues with it locking up etc.
    I used to use Netgear routers, but went with the Belkin after a PCPro review - wish I hadnt!
    What should I replace it with?
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
  3. Guest-44432
    Guest-44432 Guest
    I had a Belkin router, which I had nothing but problems with. I now have a Asus N13DSL router (Argos stock these) which runs great. No connection dropping etc.
    Cheers,
    Simon.
  4. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    WNDR3700. Still the best, in my opinion.
  5. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    netgear range max, got it after loads of problems with bt home-hub and never had a problem!
  6. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Netgear DG834N rev.1. It only has draft 1 N tech, no GbE, but it has an inbuilt modem and looks pretty cool. Shame that DD-WRT doesn't support routers with inbuilt modems, Netgear's firmware is lacking.
    EDIT: ^ That is what I have. Not what I recommend. If you have a separate modem, go for a Netgear Nxxx Gigabit. Just replace xxx with the model that has the features you want.
  7. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    WNR-3500L /w dd-wrt
    It dosn't seem to have great gui dd-wrt support, but most of the stuff is still doable via telnet. I'm personally running 3 seperate vlans (one for IPTV, one LAN + WLAN and one sepearte w-vlan for my work laptop due to interferece with network shares when using VPN).
  8. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Linksys WRT54GL. Never had any issues with it. Used wired and wireless. :)
  9. Mister_Tad
    27 Dec 2002
    Using the same here, most solid router I've ever used, have not once in over a year have I had to reboot it, and wireless speeds are simply astounding.
    Highly recommended.
    Available for around £100-110 these days, but even at the £140 I paid for it on release, bargain.
    Did I mention I like it?
  10. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Asus NT-R11, going to try out custom firmware. still on its way from ebay
  11. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Billion BiPAC 7800N
    About a week old but a heck of a step up from my Netgear DG834PN.
    So far, money well spent. Rock solid performance, and robust features.
  12. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    the stupid one which comes with sky's broadband, it is so poor, it over heats when i start gaming :(
  13. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Linksys WRT54GL + high gain antennas. I've had it for nearly 8 years without issue. Cost upwards of $160 at the time.
  14. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I got a wrt54g and a E3000. The E3000 is pretty much useless before you install dd-wrt, that took around 2 minutes and made the wireless functional. The wrt54g is a classic, lots of mods are available for it.
  15. Xyllian
    Xyllian What's a Dremel?
    24 Jan 2011
    D- link dir-655, great througput, wireless performance and range and also very stable. I have used many different routers and always had issues but ever since i got my 655 i have been completely issue free.
    It comes at a really good price as well, only downside is it wont run G and N at the same time, if you need that you will have to get a dual radio router such as the dlink 800 series.
  16. faugusztin
    11 Aug 2008
    Cisco Linksys E2000, no problems.
  17. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    Be Box. Possibly the worst router ever. Had a cisco model but it doesnt support ADSL 2+ so im with the Be Box.
  18. bemused
    bemused What's a Dremel?
    9 Jan 2011
    Got a Linksys E2000 works a treat and fixed a fair few problems I had with the Virgin supplied one which didn't seem to like VPN. My biggest problem with ISP provided routers is where they remove the ability to upgrade them, unless you flash the whole box.
  19. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    I use one of these... apart from not being dual band it works perfectly 24/7.
  20. wyx087
    15 Aug 2007
    Linksys WRT320N with DD-WRT firmware.
    awesome gigabit router with 5GHz wireless N, problem is none of my devices have 5GHz wireless N. :( gigabit LAN plus QoS makes sure it never bottlenecks, never had lag problem when torrenting while gaming :D
    IPv4 DHCP doesn't work though :( a bit annoying. can't figure out why.
