CPU Which would be quicker?
Discussion in 'Hardware' started by Micky2Shoes, 28 Dec 2010.
  1. Micky2Shoes
    Micky2Shoes New Member
    28 Dec 2010
    I have an i5 rig built by my cousin 6 months ago, it's a 750 over-clocked to 3.8 gig, with 4 gig memory which is a corsair dual chan kit. I use this pc for everyday use and then i also play games such as modern warfare 2, left for dead 2, f1 2010 etc. The pc at the moment never misses a bit, it performs everything very nice, never sat around waiting, and i get good fsp in games as he put a 5870 in.
    I am now working with virtual machines and i am findining myself using up 85-95% of my physical memory when i'm running more than 1 depending on what memory I give the virtual machine but atm i am running a dc, exchange box, and some clients etc so I need to run more
    I can buy the same dual channel kit in the pc at the moment for £45 which would take me to 8gb which should be enough for my virtual work but obviously i will lose my overclock of 3.8. If i ditch the overclock and go back to stock 2.66 gig, do you think i'll notice the extra cpu power missing when general browsing, email, and more specifically gaming?
    Thoughts?
  2. sb1991
    sb1991 New Member
    31 May 2010
    You shouldn't need to lose the overclock completely, just reduce the memory multiplier if it becomes unstable. Having more memory makes a bigger difference than having faster memory.
  3. Remeniz
    Remeniz Muted!
    18 Dec 2010
    You won't notice the difference while browsing and stuff but you will loose some FPS during gaming although I don't think it'll be much.
  4. Uxon
    Uxon Member
    14 Dec 2010
    Agree with this, should still be able to manage a decent overclock with 8 gig of RAM. 3.4GHz+ should still be quite possible.
  5. cdb
    cdb No comment
    25 Apr 2009
    Why should the overclock be affected at all? What do I not know here?
    I have an I7 860 running 3.8Ghz with 8G ram. I didn't think the amount of ram affected anything to do with overclocking?
  6. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    Hi
    we use VM's at work and memory is king. Why not get rid of your old 4gb kit and get a new 8gb (2x4gb) kit. this will give you the option to increase your memory to 16 gb if you fancy at a later date
