Motherboards Which X570 Mobo?
Discussion in 'Hardware' started by xxxsonic1971, 17 Dec 2020.
  1. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Hi, Getting some bits together for new build after xmas. Going Ryzen 3rd gen, just need to pick a nice board at around £200-£250. Any suggestions?
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    NVM.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Having just used an msi b550 gaming carbon for a build, I was amazed with how much stuff they packed on a fairly midrange board. Even had a header to connect Corsair commander to!
  4. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    the best x570 mobo for £200 is a B550 lol
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Not the Gaming Edge Wifi!
    For some reason MSI cheaped out on the VRMs for that board and it runs hot and unstable because of it. It's infamous for falling over at random, especially if you put one of the big Ryzen CPUs in it or try overclocking. MSI released the X570 Tomahawk earlier in the year and that's a much better motherboard for £200-ish, more or less the same features but chunkier power delivery and better stability.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    Please provide evidence from multiple credible sources.
    Seriously, you can't just accuse a company of something like that...
  7. fix-the-spade
    4 Jul 2011
    Erm, go read the reviews? It's not exactly a state secret. The X570 Gaming Plus has the same problems with high VRM temps. Later models like the Tomahawks and B550 boards rectify the problem, but the Gaming Edge and Gaming Plus should be avoided.
    http://der8auer.com/x570-motherboard-vrm-overview/
    xxxsonic1971 likes this.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    You are the one who accused a supposedly legitimate company of deliberately designing a product that isn't fit for purpose, so it is your duty to back it up with evidence. Basic common sense and all.
    Anyway, since you did deliver the evidence recommendation has been withdrawn and MSI blacklisted for next couple years for me.
    And thank you for the heads up about them being such utter scumbags.
  9. xxxsonic1971
    5 Dec 2010
    I have been looking at one of these
    Gigabyte
    X570 AORUS PRO (AMD AM4) DDR4 X570 Chipset ATX Motherboard
    Was: £259.99
    £209.99 *
    It seems not a bad deal from overclockers. Any thoughts?
  10. Vault-Tec
    30 Aug 2015
  11. fix-the-spade
    4 Jul 2011
    Yeah fair enough.
    Gareth Halfacree likes this.
  12. xxxsonic1971
    5 Dec 2010
    And one last question ha! Will X570 AORUS PRO support Ryzen 5800x out of box without bios update?
  13. spolsh
    spolsh Multimodder
    4 Feb 2012
    that'll be a maybe ... just depends when the board was made as to what BIOS will be on it. Looks like bios can be updated without CPU anyway.
  14. Sgoaty
    Sgoaty Minimodder
    4 Feb 2005
    I nearly bought the Asus but after a couple of really poor warranty experiences with them I vowed never again ( unless it's a crazy good deal or the only viable option )
    MSI did make up for their mistake in my eyes with the x570 tomahawk which is a far superior board to the Asus tuf for a similar price. I'd seriously consider it if I were you.
  15. Yaka
    Yaka Modder
    26 Jun 2005
    what would you guys go for asrock taichi or the msi tomahawk?
