Build Advice Which Z87 board & Cooler?
Discussion in 'Hardware' started by adam_bagpuss, 6 Jun 2013.
  1. adam_bagpuss
    24 Apr 2009
    hi guys,
    well as everyone is aware haswell has been released and i think its about time i upgraded.
    However while the CPU is an easy choice 4670K
    im not sure which mobo to pick ive looked at the ASUS Z87 pro and the ASrock Extreme 6 both have good reviews but not bit-tech reviews !
    also not sure on which cooler to opt for - i wont be pushing the chip to its limits but a healthy 4.4Ghz-4.6Ghz would be nice.
    other kit i have is;
    Fractal R3 case with 2x 120mm front fans 1x 120mm back and 1x 140mm top.
    Corsair 650W PSU
    std DVD re-writer
    1TB samsung F3
    256GB samsung 830
  2. GeorgeK
    18 Sep 2010
    The main thing to know really is what's your budget for both? The answers will vary a lot depending on that!
  3. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Currently overclocking Haswell to 4.5 or above needs some hefty cooling. Closed Loop H100i got the chip up to 90c and that was a 4770K.
    The Gigabyte OC is looking at being a great board. But at a price.
  4. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    Since Bit-Tech have posted this:
    http://www.bit-tech.net/news/hardware/2013/06/06/haswell-heat/1
    You are lucky to get 4.5 according to this ^^
  5. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
  6. adam_bagpuss
    24 Apr 2009
    id say £200 or less on a mobo.
    Im not massively going to push this chip but it would be interesting reading an article with a sandy vs ivy vs haswell at there max air cooler overclocks
  7. adam_bagpuss
    24 Apr 2009
    just done a quick price check and they are all about the same cost
    although mobos are cheaper
  8. GeorgeK
    18 Sep 2010
    Fair enough - I've literally just bought (well it arrived today) an Asus Sabertooth Z87 and it's a fantastic piece of kit. Well made and solid as hell with the backplate and thermal armour installed. Properly looks the business too & has a 5 year warranty (compared to 3 years with every other board pretty much). I've not clocked the chip yet but Prime 95 on stock clocks with a H100i gives temps less than about 55° (and my room is bloody warm this evening...)
  9. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    but are intel selling good ones to the oems, who don't normally pre-overclock machines, and saving the better ones for retail, who are more likely to overclock.
  10. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    The MSI Z87-GD65 has had some good reviews. Personally I think I'll go for a sabertooth.
  11. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    I like Asus's boards this round over the others, but some of that is the new color scheme ^^.
    On a slightly off-topic note, are LGA 1155 coolers fitting LGA 1150 without new brackets?
  12. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    Yep 1150 uses 1155/1156 fixing brackets.
  13. adam_bagpuss
    24 Apr 2009
    so what makes the sabertooth worth £200 compared to say the MSI board at around £170 or the Asus pro @ £160 ?
    Also any suggestions on coolers ? i think max £50 unless its worth stepping up. H100 is lovely but its £95 !!
  14. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
    What about Asus Z87-Delux .
  15. adam_bagpuss
    24 Apr 2009
    its £221 and doesnt really look any better than much cheaper boards
  16. Xir
    Xir Modder
    26 Apr 2006
    Even worse, The Gryphon is the smaller Sabertooth, and it cost's 1/3rd less! (~£130)
    Why so much?
    The ASUS Z87 Gryphon (MATX) £130
    or the the ASUS Z87M-PLUS (µATX) £105
    or the ASUS Z87-A (ATX) £120
  17. faugusztin
    11 Aug 2008
    If previous experiences are any indication, then i would think about the ASUS Gene and Hero boards.
  18. Dae314
    3 Sep 2010
    I really like the Z87 PLUS. It's a good balance of price and features in my book.
    As for coolers... Haswell's running hot, so probably something on a closed loop in the $60 range would be ideal if you want to do some overclocking.
  19. adam_bagpuss
    24 Apr 2009
    i think the Asus Z87 gryphon will be enough for me i dont need the extra slots and features. As long as it can overclock decently thats enough for me.
    Now on to coolers - dont really want to sink more than £50 on a CPU cooler but id be looking for 4.2Ghz+ overclock so need something that can handle that.
    I was looking at the following
    SilverStone Argon AR01 with maybe an extra fan although cant find a review - £25+£10
    Noctua NH-D14 - £65 bit overbudget but looks a great cooler
    cant have the thermalright archon as its too big 170mm !!! ive got a fractal R3 which support ~165mm
  20. faugusztin
    11 Aug 2008
    Why do you guys even think about better coolers, when it is clear the issue is bellow the IHS, so there is only a very small difference between a 20 euro tower cooler and a water cooling setup ?
