Build Advice Which Z87 board & Cooler?
Discussion in 'Hardware' started by adam_bagpuss, 6 Jun 2013.
  1. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    At present, even if you're out of luck and get one of those "unlucky" chips that doesn't overclock well, reviewers seem to indicate something like 4.4GHz as a minimum. Your 4.2GHz *should* be achievable on any air cooler you want.
    Faugusztin is right, at your level, I'd be going for acoustics over performance.
  2. Poulter
    Poulter What's a Dremel?
    22 Aug 2012
    Using the MSI Z87 G65 Gaming mobo atm, and i have to say i love it, does everything i need to, get a good overclock and some nice little features too for a very very good price!
  3. adam_bagpuss
    24 Apr 2009
    bit the bullet bought stuff
    Asus Z87 Gryphon
    8GB (2x4GB) Corsair Vengeance (red) DDR 2133 (silly not too since it same price as 1600mhz)
    I5 4670K
    Silverstone SST-AR01
  4. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Adam why did you go for Red Corsair Vengeance seeing as the mobo is a brown goldish colour?
  5. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    Congrats on the purchases Adam. You'll have to let us know what the Gryphon is like. I was going to buy one myself but ended up going for the Gigabyte G1 M5. Unbelievable pain in the aaaass to get it all into my Corsair 350D but I got there in the end :D
  6. adam_bagpuss
    24 Apr 2009
    yeah i know it will looks odd but for some reason 2133mhz modules in red were £57 but if you wanted them in black they were around £81 !!! i think they needed to get rid of stock.
    i dont have a window on my case anyway so im not fussed ill take performance over looks any day. Its going to go really well with the ice blue cooler i just got lol
    red blue and black and gold oooooohhhh yeaaahhhhh
  7. flame696
    15 May 2009
    I told myself I don't need a high spec rig and I just sold most of my stuff (see sig) but now I have the itch again damn it you people
  8. Xir
    Xir Modder
    26 Apr 2006
    Is that available?
    Havent seen a single test of it yet.
  9. GeorgeK
    18 Sep 2010
  10. Xir
    Xir Modder
    26 Apr 2006
  11. GeorgeK
    18 Sep 2010
    I would guess the lack of Bit articles was due to people being off at Computex - give it a week or so and I'd imagine that loads will start popping up :thumb:
  12. flame696
    15 May 2009
    well i just pulled the trigger on a haswell build (i know i just soild an ivybridge rig, don't judge me lol). I picked up:
    1. i5 4670K
    2. Asus Maximus VI hero
    3. 8gb Red corsair vengeance 2133mhz RAM
  13. adam_bagpuss
    24 Apr 2009
    isnt that red vengeance RAM a bargain flame :)
  14. flame696
    15 May 2009
    yeh i cant believe its soooo cheap, they must have excess stock and i think due to it come to its end of life (new vengeance)
  15. Oggyb
    Oggyb Mutant
    15 Jun 2010
    I can confirm the new Z87 Gryphon board is a nice piece of work. The boot-into-BIOS button is a useful feature and the LEDs indicating the POST process are definitely better for troubleshooting than not having them. I don't have a speaker in my chassis so I had to rely on the LEDs for much of my setup glitches.
    If you're using a matched set of memory you'll be dandy, but if you're pairing let's say a 1.65V set and a 1.5V set, the board will go through a whole bunch of tests and reboots before it works out what's going on.
    Since we have the same board/CPU combo, I managed to get 4.3GHz stable at 1.19V (actual monitored value was more like 1.2 most of the time) under an old Freezer 7 pro. AIDA64 temps mid 80s after 10 minutes, then levelled off.
  16. adam_bagpuss
    24 Apr 2009
    i think i need to re-apply my thermal paste
    im getting idle 30-35 with speed step on (800mhz-1.5ghz), with load on prime95 (3.8Ghz) its 67-70 after 2 mins
    did a mini overclock to 4Ghz and temps stayed the same
  17. flame696
    15 May 2009
    I'm getting 24-26c with speed step disabled I'm using a Antec Khuler 920
  18. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    hmm, if you are going to buy a brand new setup, why would you choose an i5 over an i7?
    from what I can see there is about an £80 difference in price. Is the performance difference between the i5 and i7 not even worth considering?
  19. adam_bagpuss
    24 Apr 2009
    i5 4670K = £190
    i7 4770K = £275
    £85 or nearly 45% more expensive
    i7 really only gets you HT and braggin rights so if your just in to gaming and dont use heavily threaded apps theres no point in buying a 4770K
  20. GeorgeK
    18 Sep 2010
    I'm getting 27-29°c with speedstep on with a H100i at idle but that's with SP120 quiet fans dialled right back on a 4770k for reference (& MX-4 paste)
    Edit: I might finally have some time this weekend for some OCing...
