Which Zalman cpu cooler?
Discussion in 'Hardware' started by cfuk, 14 Mar 2005.
  1. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    I'm after a new hsf for my 3500+ and have come to two now. It's down to the Zalman 7000B-Cu Copper LED or Zalman 7000B-AlCu LED. What's the differents in cooper or aluminum?
  2. TMM
    TMM Modder
    12 Jan 2004
    the Cu performs a little better then the AlCu, but is alot heavier :) Thats pretty much it..
  3. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    There's a small performance difference between the two, but a large price difference
  4. cfuk
    9 Jul 2004
    not worth the extra money?
  5. JuMpErFLY
    13 Mar 2003
    Depends how much money you have to burn. I wouldn't part with the extra cash myself, would only buy the all copper one if I found a good deal second hand.
  6. cfuk
    9 Jul 2004
    i have some money in a couple of days (i hope), but don't want to be spending £10/15 extra if i don't need to
  7. JuMpErFLY
    13 Mar 2003
    You don't need to ;)
  8. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Agreed.
    I have the 7000-Cu, and frankly it's not worth the money over the aluminum...also, the weight causes a seating problem if you move your case much at all.
    If I had it to do over again with air cooling, I'd go for the AlCu. I love the Cu cooler, but it's just not worth the $$.
  9. cfuk
    9 Jul 2004
    well i've put in an order for the alcu :)
