Hello, Can i pick your brains as i have done a fair bit of searching and what im after is a fan that looks like the black and white Fractal design fan that i will be getting with me ARC Mini case. But i want it to light up blue with LEDs.. anyone know of anything? TIA
Hmm that's a tricky one. I can only seem to find clear with blue LED's. All i can suggest is getting clear/smoke/black ones with blue LED's and painting them white I'm afraid.
It's pretty easy and very cheap to add LEDs to a fan yourself, and there are plenty guides online on how to do so. Even club together with a mate, set aside a day, and do a few. Here is a good one on OCAU.
Thinking im gonna add some UV leds.. should light the white up a treat on the fractal fans. Just ordered a Fractal Arc Mini that has 2x 120mm and 1x 140mm with an additional fan of each side.. should run cool!
Yea after months of looking decided to go small and compact.. should run cool enough i dont have a crazy system etc.. no SLI etc
So after building the system in my new case... i go to look on scan for a CPU cooler. what do i find? http://www.scan.co.uk/products/200m...an-700rpm-fan-with-blue-led-and-braided-cable Shame i already got 3x120mm Fractal and 2x140mm Fractal fans as well as 20 pre wired ukltra bright 5 mm blue LEDs. Oh well... Least i not have a back up plan. Anyone got any thoughts on the Arctic Cooling Freezer 13?
