Case Mod - In Progress White MINI
Discussion in 'Project Logs' started by shuhong90, 19 Jul 2012.
  1. Scrappy
    Scrappy Mod in progress!
    10 Jul 2011
    I am loving the colour scheme.. nice job on the psu :) & i see what you mean with the graphics card cover it looks nice and white with black screws but maybe use some small mother board stand offs so it isnt as much in contact with the card and maybe use some small washers to stop them touching the board of the card, but i don't know they are just suggestions :) i hope i could help and very nice mod and colour scheme so far :)!
  2. skitzab1
    skitzab1 What's a Dremel?
    21 Apr 2012
    nice work :)
  3. shuhong90
    shuhong90 What's a Dremel?
    9 Mar 2012
    Thanks for the liking guys =)
    Weekend is the best day for modding and updating worklog !
    So here I am again, to share some progress, thought its only a few pictures, but still, am so eager to share :foot:
    The original XSPC 240 radiator in matte black !
    Next, spending approximately 2-3 hours sanding~
    Next will be white primer and pure white paint :nod:
    and finally the result :beard:
    With some fittings on :blush:
  4. shuhong90
    9 Mar 2012
    Upcoming...
    sigh fittings are jz not enough
    Scirocco likes this.
  5. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    I tell you what.... i like it... i like it alot, from the close ups it looks like the fittings and the rad could use a second coat of white, but thats just me being an arse.. lol looking forward to seeing this progress. looks good.
  6. shuhong90
    9 Mar 2012
    Thanks for the suggestion and liking bro, it may not look like it, bt it already been coated with 3-4 layers of primers and 6 layers of white paints :eek: . but still, will consider painting more layers, to make them looks more , uniform, thanks again :thumb:
  7. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    that is epic looking man, keep up the good work :):rock:
  8. Telefonskaft
    Telefonskaft What's a Dremel?
    31 May 2011
    Looks awesome! :D
  9. shuhong90
    9 Mar 2012
    Thanks guys :clap:.. it will be some time before next update :wallbash: so bear with me :sigh:
  10. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Looking really awesome.
    jus one thing. why the fittings in the middle of crystal link? one single acrylic tube would look lot nicer. plus you would not run out of fittings.
  11. shuhong90
    9 Mar 2012
    the longest size of the crystal link available is limited to only5 slots. that is why.
  12. tekonivel
    14 Jul 2012
    just get same diameter acrylci tube from locan acrylic company.
  13. epetersson
    epetersson What's a Dremel?
    3 Aug 2012
    Looking good! I love the prodigy case!
  14. JitsuSparty
    JitsuSparty Minimodder
    25 Apr 2011
    looking good - I am thinking of building a Prodigy based PC, and thanks for the great ideas about water cooling.
    unfortunately when my black case turned up I took the sides off and found the screw holes holding the plastic handles were cracked and broken :( so back to the suppliers with the case...
  15. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    you wont get them uniform, it's the different surface of the parts that makes them get the different tone! i've worked as a paint saler and matching color is the single hardest thing you can do... as long as there is different materials/finish on the surfaces iäm quite sure you can't get them even :/
    I, am however NOT a painter so i might speak a LOT of rubbish right now! :/
    i think it looks fantastic! :D :clap: :clap: :clap:
  16. shuhong90
    9 Mar 2012
    :rock:
    dont worry, all the waiting will give u more time for even splendid ideas :thumb:
    yes, I strictly agree ! and thanks for the clarification ! :blush:
  17. JitsuSparty
    25 Apr 2011
    Your right - I had a flash of inspiration last night and am planning on building a battlestar Galactica themed case - working title "So Say We All"
  18. shuhong90
    9 Mar 2012
    :thumb::thumb::thumb::thumb: ENjoy the build !
  19. JitsuSparty
    25 Apr 2011
    To come back to the topic here. Loving the look of the radiator and fittings
  20. shuhong90
    9 Mar 2012
    Finally my motherboard came ! ! =)=)=)
