Case Mod - In Progress White MINI
Discussion in 'Project Logs' started by shuhong90, 19 Jul 2012.
  1. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    brilliant colour on that board. Also I have never seem a board battery vertical before, I hazard that board space is such a premium it had be be that way.
    Keep up the good work.
    Ed
  2. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    That board looks super smexy :)
  3. Wissel
    Wissel What's a Dremel?
    12 Aug 2012
    Looks so far like one of the nicest prodigy builds I've seen - look forward to seeing it done.
  4. alain-s
    alain-s Minimodder
    12 Jan 2011
    Very nice really love the colour White. :rock: What fluid colour will U be using?
  5. shuhong90
    shuhong90 What's a Dremel?
    9 Mar 2012
    Thanks guys :D
    I'm thinking to use white as well :D
  6. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Love it, just got myself one of these cases to experiment with some watercooling goodness :D
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Grat work man :), im actually onto a project with the same case.
    Mine will look totaly different and i wil be using 3 or 4 rads into the case and a lot of more goodness :)
    I will keep you updated when i have had time to start the projectlogg :)
  8. shuhong90
    9 Mar 2012
    Finally my camera is back :lol: some photos to show what had I've done over the weekend ~ Cutting out a rectangular hole for modular cables, and better cable management :lol:
    Too bad I didnt manage to take any photos during the process, but anyway, here are the results of bending 3mm aluminium plates, creating a bracket to hole a plate in the side panel, hiding ugly cables.:p
    The plate required some clean off by acetone, so much adhesive :facepalm:
  9. KoSoVaR^
    19 Dec 2010
    looks great dude, haha the case looks like its Military green on the photos :p
    Your whitebalance on the dslr are not correct
  10. shuhong90
    9 Mar 2012
    Thanks for your reminder, but I'm aware of it , the purpose of these photos is to show the result of mobo tray, so i didnt particularly putting some effort in setting correct white balance. :D
  11. shuhong90
    9 Mar 2012
    More updates,
    gotten some extra fittings, hopefully this will be enough.
    Sleeved the cables for power on off. leds etc.
    Finished painting the metal plate, cable management etc.
  12. KoSoVaR^
    19 Dec 2010
  13. shuhong90
    9 Mar 2012
    When pump meets reservoir
    with f/1.8
    with f/3.2
    Hope you guys like the photos =)
  14. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    Oh wow, this is going be sick! Great job so far! :D
  15. WALKYRIE
    WALKYRIE What's a Dremel?
    29 Aug 2012
  16. shuhong90
    9 Mar 2012
    Thanks:thumb:
    because great number of ppl are sticking to black-only colored, which could be boring at some extents, and hardly stands out. but too bad, white pcb are'nt that common unless u paint the pcb :rock:
  17. spigs_rex
    spigs_rex What's a Dremel?
    1 Oct 2010
    ah looking good ...your fittings are well painted how did you do them? just pop off the seals n spray them?
  18. shuhong90
    9 Mar 2012
    Its preferably to sand, primer and den paint.
  19. NeoSSX
    NeoSSX What's a Dremel?
    2 Sep 2012
    I've got the Bitfenix Prodigy and I'm thinking of getting the Silverstone ST60F-P as well. I was wondering if you could fit the power supply and cables in without the need to make a hole?
  20. shuhong90
    9 Mar 2012
    Gotten this over the last weekend ! ! ! ! Canon EF 24-70mm USM f1.8 L ! ! ! ! !
    Gotta say this monster is realllll goood ! :cool:
